Hay mower
   / Hay mower #1
qed-cat225
Sullivan, WI
2011 Bobcat CT235
other than a sickle mower is there any other type of Hay mower a CT235 could handle on a small scale?
   / Hay mower #2
A "drum mower" would be well suited to your small tractor.
   / Hay mower #4
Right on. Get a 5-ft drum mower. Cost will be about $3K plus shipping (about half the cost of a similar size disc mower). Drums will not clog like sicklebar mowers, will cut any type of vegetation regardless of the moisture situation, cut fast at high ground speed, are simple machines that require minimal servicing, and the blades are inexpensive and quickly and easily changed in the field.
Good luck.
   / Hay mower
so who are good manuf of drum mowers?
   / Hay mower #6
Kuhn and Kubota make a small one and there are several itiallian ones out there. I would suggest you first rent one from your local AGG dealer or rental place that handle agg equipment. I run a 9' IH 1300 sickle mower with no issues. does very well for me.
   / Hay mower #7
One other question - what do you plan to use for a rake and baler?
   / Hay mower #8
   / Hay mower
thanks for the google advice i had not thought of that...
   / Hay mower #10
I have owned the ranch rite drum mower for two years. Works fine on my CT235.
RIMS AND TIRES (A50854)
RIMS AND TIRES...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
2012 MACK PINNACLE CH613 FLAT TOP DAY CAB ROAD TRACTOR (A51243)
2012 MACK PINNACLE...
New Holland HM236 Disk Mower (A50515)
New Holland HM236...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
