Hay forks
/ Hay forks #1
Aggie66
Rockdale TX
MX 5400
I own a Kabota MX 5400 and i’m just getting some of my pasture hayed for the first time. I don’t own a set of hayforks and I was just wondering if you guys that do haying have recommendations on forks two prong three prong round, prong, etc. I’m not going to be producing much hay probably 15 rolls max. I know some operators use a fork on the back and a fork on the front. I will be loading a customer’s trailer and the rolls are 1300 to 1500 pounds. Any recommendations appreciated
/ Hay forks #2
I would start with loader mounted spear for loading. If you're carrying a long distance to and from the field to storage, or storage to the customer's vehicle you can add a 3 point spear to save time.
A regular set of forks will do just fine if you already have the them although you might end up forking a little dirt now and then. 😉
/ Hay forks #3
If this is something you plan to do each year invest in a QA bale spear, one long prong and two small prongs.
I have both chain on style that goes on regular bucket and QA one. The chain on one is awkward and puts the bale way out front, but fits any loader bucket. QA one way nicer and keeps the bale closer to the loader arms.
/ Hay forks #4
With that few bales being handled, I’d be looking on FBM for a used bale spear. I like 2-prong versions better than one prong with the 2 auxiliary prongs. They are more useful for other tasks.
Another thought is if you are also considering pallet forks, they can be used for round bales.
I have a 3 full length prongs which can handle large squares and many other tasks
/ Hay forks #5
When I was looking, I decided on a two spear model. I read that it was more stable then one spear, but otherwise, I really don't know if that's true or not. I also use it for lifting pallets, carrying rolls of fencing and fence posts, so it's come in handy having two spears.
/ Hay forks #6
I use mine to carry saw logs and anything else too long to fit in the bucket. Pretty much hay spear/pallet fork in my use. Real handy to lift and carry the concrete railroad ties I have all over the place. The spears dig under them really nice and I can carry 3 at a time.
/ Hay forks #7
A two spear FEL set-up is my recommendation. It's stable for lifting, especially when loading, and for transporting.
ENSURE that you have ample ballast on the 3PH.
/ Hay forks #8
Many people use a bale on the back to ballast the one on the front
/ Hay forks
Can you send me some recommendations and web links so I can get an idea of what could work for me. I hate to be ignorant on this but I’ve got 15 bales on the ground now and now need to be able to load them. Thanks.
/ Hay forks #10
Ck your mail.
/ Hay forks #11
I always kinda found in my operation that the “sticky” bales were the ones with excessive moisture, or baled too early and the stems were still damp.
When I did rounds, I used a 2-long prongs set up. Mush better stability and could be used to pick up 2 bales at once.
/ Hay forks #12
I bought a set of chain on ones for my TLB and they are handy for the large squares, and also use the grapple on my tractor, with the MX probably best to just go ahead get a quick attach bale spear like has been posted for round bales.
/ Hay forks #13
I would buy something made from HLA. Might not work for you in Texas though.
If you are in an hurry and you have a SS QA, almost any farm dealers should have a SS QA bale spear on the lot. Not sure current price, but they USED to be well under $500.
/ Hay forks #14
X2 ^^
I run a lot of HLA attachments. My bale spear is HLA.
Forks & Grapple, too.
Solid, farm grade equipment
Takeuchi TB225 (A62177)
Takeuchi TB225...
Cattle Feeder (A65640)
Land Pride 3Pt Mower (A66408)
Land Pride 3Pt...
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
Blue Diamond Mini Excavator Brush Cutter (A64126)
Blue Diamond Mini...
2018 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 PETERBILT 579...
