Hay Folks ! new guy in Loxahatchee Fl.
   / Hay Folks ! new guy in Loxahatchee Fl. #1
Bob Phalen
Boca Raton
Kubota M5040, B7800
Hello ,Glad I found you guys.We have a small tree farmer in Loxahatchee Fl, we also have a couple Kubota tractors .. M5040 and a B7800.
I could really use some suggestions on how to take the Hydraulic pressure off the system in order to connect a Grapple to the front end.
Does Kubota make any type of pressure release valve? Is there after market add on I could install?
Thanks for any and all help, Bob Phalen:confused:
   / Hay Folks ! new guy in Loxahatchee Fl. #3
:welcome:
Happy you found us!
I'm going to move this thread over to our Kubota section to see if we can find you an answer.
   / Hay Folks ! new guy in Loxahatchee Fl. #4
I find the best way to relieve hydraulic pressure is to operate the valve while the tractor is off.
   / Hay Folks ! new guy in Loxahatchee Fl. #5
G'day Mate and welcome to TBN from Downunder.
As wagne223 suggests, you need to fully relieve the pressure in the 3rd function lines to easily attach (and remove) those hydraulic couplers. That means, turning the tractor OFF, working the joystick in all 4 directions/planes and then working the 3rd function button/joystick in its 2 directions/planes. You should hear a "clunk" when that happens = the pressure is relieved.
Enjoy the site.
   / Hay Folks ! new guy in Loxahatchee Fl. #6
:welcome:
To the TBN forum Bob. You came to the right place to get any question answered.
As wagne223 suggests, I do that to relieve the pressure every time I turn the tractor off.
   / Hay Folks ! new guy in Loxahatchee Fl. #7
:welcome: to TBN Bob...enjoy.
   / Hay Folks ! new guy in Loxahatchee Fl. #8
Yup me too--On the tractor and RTV..If you don't, them suckers are tough. If it's sitting in the hot sun, it's 10x worse.
Thanks Catherine, that helped a lot. Got the answer right away from a bunch of folks.
Thanks folks, that did it! Now that I think about it makes perfect sense.
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
Orico 3000 Cook Top (A51573)
Orico 3000 Cook...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2009 Ford F-650 24 ft Box Truck - 6.7L Cummins L6 Engine - Automatic Transmission - Low Mileage (A53472)
2009 Ford F-650 24...
28013 (A50322)
28013 (A50322)
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53472)
2019 Energreen EVO...
