Tiller having a heck of time getting the pto shaft hooked up on the tiller...any advice?
   / having a heck of time getting the pto shaft hooked up on the tiller...any advice? #11
Ive had some similar problems. Usually once per year I take a wire "toothbrush" and some WD40 and clean up both the male PTO and the female PTO coupling. Then wipe it down and visually inspect it very carefully. If a little ding or burr is found, then dress it with a file or emery cloth and you'll be fine. OBTW, a good pair of reading glasses are helpful, if you're as old as me...!
   / having a heck of time getting the pto shaft hooked up on the tiller...any advice? #12
This may or may not help.....
My tiller was a bear to get on. Then I got Pat's Easy Change, and the shaft slipped on very easily. I thought about it for a minute, and realized the shaft was too long, and PEC extends the implement out by 4 inches or so. So I solved a problem I didn't know I had, in addition to making the 3ph attachment easier.
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
294 (A52706)
294 (A52706)
2016 Chevrolet Tahoe (A55973)
2016 Chevrolet...
2014 Takeuchi TB290 Mini Excavator, S/N 1851007797, Diesel Engine, Tag 24" Bucket w/Thumb, 18" Wide (A59076)
2014 Takeuchi...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
