Tiller having a heck of time getting the pto shaft hooked up on the tiller...any advice?
   / having a heck of time getting the pto shaft hooked up on the tiller...any advice? #11
Ive had some similar problems. Usually once per year I take a wire "toothbrush" and some WD40 and clean up both the male PTO and the female PTO coupling. Then wipe it down and visually inspect it very carefully. If a little ding or burr is found, then dress it with a file or emery cloth and you'll be fine. OBTW, a good pair of reading glasses are helpful, if you're as old as me...!
   / having a heck of time getting the pto shaft hooked up on the tiller...any advice? #12
This may or may not help.....
My tiller was a bear to get on. Then I got Pat's Easy Change, and the shaft slipped on very easily. I thought about it for a minute, and realized the shaft was too long, and PEC extends the implement out by 4 inches or so. So I solved a problem I didn't know I had, in addition to making the 3ph attachment easier.
New/Unused SD Lanch 20x30 All Steel Carport (A57454)
New/Unused SD...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
2003 Volvo L60E Wheel Loader w/ 3 in 1 Bucket (A59213)
2003 Volvo L60E...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
2017 Komatsu WA500-8 Wheel Loader, S/N A96097, PIN# KMTWA134LGNA96097, Komatsu Turbo Diesel Engine, (A59076)
2017 Komatsu...
