Having a hard time finding dust caps for the couplers
   / Having a hard time finding dust caps for the couplers #21
Thanks Aaron - at least someone can work their way around a hydraulic system and make sense of what is there !
Well, I came up with a temp but decent solution for the female coupler. I'll still keep an eye out for the correct plug that goes inside the female coupler.
Thank you all for your inputs.
   / Having a hard time finding dust caps for the couplers #23
   / Having a hard time finding dust caps for the couplers #24
JJ, right on. With the internet now at our fingertips these things should get resolved quick. The OP never did tell us what the brand name and part number his QCs are. Wow, Amazing
Ron
Ron
Ron,
I'm not sure if I'm reading the description correctly but I think this is what it says: FRESTEA NV38 38SAE F-12MO, Made in Italy.
Cheers.
   / Having a hard time finding dust caps for the couplers #26
Alia,
Appears all the posters on this thread were recommending workarounds. What does your tractor dealer say? They may be your only source for foreign made parts even though they probably mark them up 100% or more. I only go the the dealer when that happens or the item is made by them exclusive to a product.
Ron
   / Having a hard time finding dust caps for the couplers #27
You can bet the tractor dealers are buying from venders.
I don't think Kubota and JD make their own.
   / Having a hard time finding dust caps for the couplers #28
Go to ebay. look up "Thesmartfarmer". he has 1/2 and 3/8 inch caps and plugs.
When you buy now, or bid, you have to let him know what size you need.
good luck
Tom
That's a really good deal. I've been able to find caps but not color-coded, and very expensive.
I have ISO Ag connectors, Parker 4000s which are ISO 5675. Do those connectors work for them?
   / Having a hard time finding dust caps for the couplers #29
You might try here: McMaster-Carr
Plain vinyl caps are pretty inexpensive. The caps with hanger eye look almost ideal if the diameter fits.
   / Having a hard time finding dust caps for the couplers #30
How about just rinsing them off before you connect you attachments? a little WD40 or? not that big a deal.
UNUSED IRANCH IRGC40 HIGH END MINI GOLFCART (A54757)
UNUSED IRANCH...
2020 VOLVO VNL TANDEM AXLE SLEEPER (A54313)
2020 VOLVO VNL...
UNUSED (1) 3500# AXLE W/ BRAKES (A54756)
UNUSED (1) 3500#...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2011 FORD F-150 Crew Cab Pickup Truck (A55788)
2011 FORD F-150...
NEW Woods 6ft Finish Mower (A55218)
NEW Woods 6ft...
