Have to Return Cracked Steering Wheel on New RX7320PC Before I Get Replacement
   / Have to Return Cracked Steering Wheel on New RX7320PC Before I Get Replacement #11
The dealer did do a pre-delivery inspection on my tractor. I actually watched the service techs do it & I got a pre-delivery check list when they were finished. The main reason I observed the pre-delivery inspection/service - I got to see where all the grease zerks were without the normal hunt/poke/squeeze and then check the Op Manual situation.
About two years after I had the tractor there was an upgrade to the step - I guess there had been problems with the step bending. They came out to my house and did the step upgrade right there - I didn't have to bring the tractor in for that service (50 mile round trip).
Its service like this that keeps me going back to this dealer.
   / Have to Return Cracked Steering Wheel on New RX7320PC Before I Get Replacement #12
Yes, when I replaced mine I removed the bolt under the cap and popped the wheel right off. It may be possible that you will need to use a puller to get the cracked one off but, as new as your unit is it will probably come off with no problem.
   / Have to Return Cracked Steering Wheel on New RX7320PC Before I Get Replacement #13
Exactly - they make a steering wheel puller for taking them off but often you can just unbolt and tap with a rubber mallet. The other option if it is stuck is a gear puller will often work just fine.
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A57880)
2000 GMC C7500...
1998 CATERPILLAR 953C CRAWLER LOADER (A52707)
1998 CATERPILLAR...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
UNUSED SDLANCH PORTABLE WOOD CHIPPER (A57193)
UNUSED SDLANCH...
2010 Chevrolet Equinox SUV (A55853)
2010 Chevrolet...
UNUSED PABREAK GCC56-2 PRONG HAY SPEAR (A57193)
UNUSED PABREAK...
