Have to Return Cracked Steering Wheel on New RX7320PC Before I Get Replacement
   / Have to Return Cracked Steering Wheel on New RX7320PC Before I Get Replacement #11
The dealer did do a pre-delivery inspection on my tractor. I actually watched the service techs do it & I got a pre-delivery check list when they were finished. The main reason I observed the pre-delivery inspection/service - I got to see where all the grease zerks were without the normal hunt/poke/squeeze and then check the Op Manual situation.
About two years after I had the tractor there was an upgrade to the step - I guess there had been problems with the step bending. They came out to my house and did the step upgrade right there - I didn't have to bring the tractor in for that service (50 mile round trip).
Its service like this that keeps me going back to this dealer.
   / Have to Return Cracked Steering Wheel on New RX7320PC Before I Get Replacement #12
Yes, when I replaced mine I removed the bolt under the cap and popped the wheel right off. It may be possible that you will need to use a puller to get the cracked one off but, as new as your unit is it will probably come off with no problem.
   / Have to Return Cracked Steering Wheel on New RX7320PC Before I Get Replacement #13
Exactly - they make a steering wheel puller for taking them off but often you can just unbolt and tap with a rubber mallet. The other option if it is stuck is a gear puller will often work just fine.
2019 Ford F-250 Super Duty Crew Cab (A55852)
2019 Ford F-250...
UNUSED WOLVERINE TDB-11-84W 84" BUCKET (A57193)
UNUSED WOLVERINE...
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
2013 John Deere 350G LC Hydraulic Excavator (A56857)
2013 John Deere...
2011 Ford F450 Diesel with Just 156638 Miles (A57024)
2011 Ford F450...
250 GALLON DIESEL FUEL TANK (A57192)
250 GALLON DIESEL...
