Have to raise Forward/Reverse lever to crank.
   / Have to raise Forward/Reverse lever to crank. #1
2dawoodz
I have to raise (find the sweet spot) the Forward/Neutral/Reverse shift lever left of the steering wheel half way b/w Neutral and Forward before the 1920 will turnover/crank. What do I need to replace/adjust? This is a friend's tractor and he tells me he has always (purchased used) had to do this.
   / Have to raise Forward/Reverse lever to crank. #2
My 1920 is same onshuttle lever. Could be many worn things causing it. But it does make it harder to steal.
   / Have to raise Forward/Reverse lever to crank. #3
I am not familiar with the 1920. I have a Ford 4610 and it has a neutral switch that has to be made before it can crank. It gets out of adjustment and you have to move the high-neutral-low shifter to get it right.
It seems to me you have a switch in your system that needs adjusting. Just a thought.
   / Have to raise Forward/Reverse lever to crank. #4
From the manual:"The transmission neutral switch is a rotary type switch that has a small pin that fits into a groove in upper end of shift lever shaft. To adjust switch, loosen switch retaining screws and move switch until continuity is indicated at switch terminals."
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
