Have to raise Forward/Reverse lever to crank.
   / Have to raise Forward/Reverse lever to crank. #1
2dawoodz
Bronze Member
I have to raise (find the sweet spot) the Forward/Neutral/Reverse shift lever left of the steering wheel half way b/w Neutral and Forward before the 1920 will turnover/crank. What do I need to replace/adjust? This is a friend's tractor and he tells me he has always (purchased used) had to do this.
   / Have to raise Forward/Reverse lever to crank. #2
My 1920 is same onshuttle lever. Could be many worn things causing it. But it does make it harder to steal.
   / Have to raise Forward/Reverse lever to crank. #3
I am not familiar with the 1920. I have a Ford 4610 and it has a neutral switch that has to be made before it can crank. It gets out of adjustment and you have to move the high-neutral-low shifter to get it right.
It seems to me you have a switch in your system that needs adjusting. Just a thought.
   / Have to raise Forward/Reverse lever to crank. #4
From the manual:"The transmission neutral switch is a rotary type switch that has a small pin that fits into a groove in upper end of shift lever shaft. To adjust switch, loosen switch retaining screws and move switch until continuity is indicated at switch terminals."
2012 Buick Enclave Premium SUV (A53117)
2012 Buick Enclave...
2003 Peterbilt 330 T/A Progress A90LS 4,500 Gallon Fuel Truck (A51692)
2003 Peterbilt 330...
2005 National RV Inc. Dolphin LX RV (A53117)
2005 National RV...
2017 Caterpillar D5 K2 LGP (A53473)
2017 Caterpillar...
2012 Ford F250 XLT, Super Cab Long Bed (A52384)
2012 Ford F250...
Unused 2025 SDLANCH SDLL30 Mini Track Loader Skid Steer (A51691)
Unused 2025...
