Have to crank DK 45 SE longer to start
   / Have to crank DK 45 SE longer to start
JimR, No, You have to turn switch to the right to "on".
   / Have to crank DK 45 SE longer to start #12
That stinks. You are at the mercy of their system. There should be a temperature switch involved also. Mine won't activate automatically unless it is cold enough. I can override it by doing it manually.
An update. I did one more test to eliminate any possible wire issues. I jumpered from preheat controller voltage output to glow plug relay. Still did not activate relay. It all points to the preheat controller. I have ordered one and should have it early next week.
   / Have to crank DK 45 SE longer to start #14
Hopefully that fixes your problem.
Time for an update. Part arrived Monday. Not what I ordered. I ordered a preheat controller and got a safety unit, Started Ebay return process and very shortly had a return authorization and a shipping label. I called Perry Power and explained that I still want the preheat controller. They agreed to relist it on Ebay. Ordered it again. Turns out they really didn't have one. I was told they should have some in a couple of days. Now I take my hat off to Perry Power. They were quick to react to an issue and just as quick to notify and apologize for the inventory issue.
The odyssey is over. Week and a half ago I ordered a controller from another Maine dealer. They didn't have it in stock but said Kioti did. Finally got it late yesterday and installed it this morning. 42 degrees out and started instantly. Back to normal.
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
2013 Ford F-750 Pak-Mor 16 CuYd Rear Loader Garbage Truck (A56858)
2013 Ford F-750...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2014 INTERNATIONAL  DURASTAR 26FT BOX TRUCK (A58017)
2014 INTERNATIONAL...
2003 TRAIL KING TRI-AXLE BELLY DUMP TRAILER (A58214)
2003 TRAIL KING...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
