Tiller Have B7610 need advice on Tiller size.
   / Have B7610 need advice on Tiller size. #11
I have a B7510 and have a 5' King Kutter tiller. Clay or breaking new ground is pretty rough. I usually run the tiller in 540 rpm with a high engine rpm on the first pass then 960 rpm and low engine rpm on the second pass. It makes for a very powder like soil. I MUST do this in LOW range and 1st gear, not enough HP to do any other way. If I had it to do all over again I would get a more narrow tiller.
   / Have B7610 need advice on Tiller size. #12
nitroxn,
For your part of the country with most likely 100% clay,you may even be better off getting a two bottom 12" turning plow to break the ground initially. Tilleingclay,,,,on unbroken ground really taxes,,,even a heavy tractor/tiller combination. If you could find a decent priced two bottom 12" plow,,if you tractor struggles to pull it in the clay,,,all you have to do is take one of the bottom off. try and find a plow that still has the coulters on it,,also. This is actually hard to find,as most guys have ditched the coulters on older plows. These really help,,,when turning unturned clay / sod for the first time!
Take Care,
Barry
   / Have B7610 need advice on Tiller size. #13
I got a 48" and a B7500 and I can't imagine using anything bigger. Now, 'round here we got lots of clay and mutiple passes is required but it still is amazing to me how well they work.
   / Have B7610 need advice on Tiller size. #14
I have a 5ft tiller on a B2910 and I can't imagine having a bigger tiller. The weight is a factor and on each additional pass while breaking new ground I can feel it cutting through the soft tillings and hitting the hard ground beliow. Tilling works a machine hard... So going slow is the best way to be kind to your equipment. I broke ground on a new garden this year, and I tilled right from field sod. I tilled 5 passes and added 15 or 20 yards of well composted manure and tilled 4 more times. So even having a bit more HP than you, I still went slow.... Also up here in New England... We have rocks!... I'll attach a pic... you can see around the edges the rock have been picked out and layed to the side.
Regards,
Chris
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A56857)
2009 Yale...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2014 F-150 STX (A56435)
2014 F-150 STX...
NEW Woods Reverse Rotation 5ft Tiller (A55301)
NEW Woods Reverse...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
