Hauling the Bota
   / Hauling the Bota #21
Nice trailer :
Have you ever used it to haul dirt sand or gravel.
If so how do you get it unloaded?
BX 24 said:
Original and rebuilt .... $750 for the trailer and about $500 in tires, fenders, new deck wood and paint. The back started out straight and I cut it so the back 2 feet dropped down. Fun project ....
   / Hauling the Bota #22
Nice trailer :
I have a similar trailer to firefighter's except its 16 ft and has permanent metal railing all the way around. I put 2X12's all the way around using u bolts so it would hold firewood and gravel without spilling anything. When i unloaded the trailer, I just drive up the ramp and scoop up the stuff and drive back off.
Does this help to answer your question lbrown?
   / Hauling the Bota #23
Nice job on the trailer. Makes me think that I should rebuild mine this spring.
   / Hauling the Bota
Very nice trailer rehab BX. Good looking work. Did you stain the decking? The color almost looks like you used Trex decking.
I use to do the same the same as Brown, with the 2 x 12 sides I could haul mulch, fire wood etc, then drive up the ramps, grab a scoop....
The problem was unloading all at once. Ie firewood, doesn't lend its self to scoops too (especially on these smaller tractors) well and taking a load of roofing material to the recycling center, I got tired of unloading that by hand so I figured I try the dump trailer.
I all ready see the pros and cons of both. Looking forward to the summer so I can really start to use the dump trailer to its full potential...
Actually I already hauled a load of snow.....emptied the trailer in under 60 seconds. THAT WAS NICE:D
   / Hauling the Bota
BX the one thing I see you are missing,.... A quick pin tongue jack, keeps you from having to crank that handle around 30 times to stow the jack...
I already ordered one for my new trailer. I love this one from Northern Tool
Bulldog Square Tube Trailer Jack — 5000lb. Capacity | Trailer Jacks | Northern Tool + Equipment
   / Hauling the Bota #26
\ When i unloaded the trailer, I just drive up the ramp and scoop up the stuff and drive back off.
To avoing going up an down the ramps with the tractor I was considering scooping or pushing the dirt gravel etc off from the sides of a deck over.
It may even be possible to do that with a fendered trailer.
Anyone tried unloading a trailer of either type that way?
   / Hauling the Bota #27
*I got tired of unloading that by hand so I figured I'd try the dump trailer.
Here is comething I may also find handy in unloading a trailer
Could push or pull stuff from either side or the rear of the
trailer.
*That's where a pick up with a dump bed that I am wanting to pull a trailer with would be great. http://s283.photobucket.com/albums/kk286/lb59/?action=view&current=100_2442-1.jpg
   / Hauling the Bota #28
1*I could haul mulch, fire wood etc, then drive up the ramps, grab a scoop....
2* dump trailer
1*With this method the tractor has to be at the unloading site. Con.
2*Don't need a tractor at the unloading site.Pro.
   / Hauling the Bota #29
Firefighter,
I haul my L-3400 with a 16' dump trailer, and I love it. I've used it to haul sand, gravel, topsoil, lumber and logs, and the unload is fast (except in winter). The front bulkhead is taller than the sides and I mounted a pressure treated 4x4 on top of it to set my bucket and forks on. This works pretty well for me. And, although I was worried at first of clearance problems with my pickup cap, it has not been a problem.
My only clearance problems have been with the backhoe and the brush hog sticking out the back. With the backhoe, I drop the bucket over the rear gate after I've closed it. With the brush hog, I've bungied the rear gates closed as well as secured them fully open (mine will fold flush with the sides of the trailer). It sticks out about 2 feet - a red flag and I'm all set.
I did get some of those ladder protectors made for protecting siding from the ends of an extension ladder. I slip those over the ends of the forks to prevent headaches while hitching or unhitching. :)
I went to a place that makes tarps for semis and had a a real heavy vinyl tarp custom made to fit the trailer - it fits like the lid of a shoebox. I also installed a small battery charger in the battery/pump box. 30' jumper cables (mine have the connector in the grill of the truck) come in handy for winter dumps when the hydraulic fluid is like molasses.
I plan on replacing the battery/pump box with a larger toolbox to house the hydraulics as well as chains, straps, traffic cones, etc. I'll probably add another battery at that time also. I'm a little ticked that the manufacturer used such a small box - it only has room for the hydraulics and one battery. I'm also thinking about adding a winch for loading, and perhaps some tubes to the bottom of the frame that I can store the forks in.
I've been very happy with the dump trailer - I've gotten a lot of use out of it.
Marty
   / Hauling the Bota
I use to do that also. Spent more time shoveling crap in to the bucket. Unless the trailer is perfectly level with the bucket, and you have a large pile, its more effort than its worth
TAKEUCHI TS60R SKID STEER (A51246)
TAKEUCHI TS60R...
2003 Ford Excursion 4x4 (MPV), VIN # 1FMSU43PX3EC07978 (A51572)
2003 Ford...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2003 Chevrolet Express Van, VIN # 1GCFG29T831102997 (A51572)
2003 Chevrolet...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2005 Chevrolet Silverado 1500 Pickup Truck, VIN # 1GCEC19V35Z257979 (A51572)
2005 Chevrolet...
