Hauling A BX23
   / Hauling A BX23 #1
HoggyB
Hi, all-
I'm looking to pick up a BX23 tomorrow.
I have a 5' x 8' utility trailer with sides that I would like to haul the tractor (I'M BUYING A TRACTOR!!!!!!! I'M GETTING A BACKHOE!!!!!!!!! WHOOOOO HOOOOOO!!!!!!!!!!).
According to my dealer the tractor, with loader and backhoe, will weigh less than 3,000 lbs, which puts it within the trailer's weight range.
And according to Kubota's website, the tractor is only 48" wide (at the bucket?) which is well within the 5' width of my trailer.
The length, however, may be my downfall. According to the Kubota website, the tractor's length is 92.1"/173". I'm not sure how to read this, but after looking at the specs for the BX2200, I see it has a length of 92" and I am assuming the BX23 itself is only 92" long with the loader/backhoe making up the difference. If this is true, could I get my tractor to fit in my trailer by letting the loader stick out the front of the trailer, while letting the backhoe stick out the back of the trailer?
I could rest the loader on the front wall of the trailer...
If this is a dumbhead idea, I'll rent a trailer, but it would be really nice to be able to move my tractor in my utility trailer, so I can haul it to my mom's house from time to time to help her out.
Hog
PS- Happy Thanksgiving!
   / Hauling A BX23 #2
/forums/images/graemlins/confused.gif You need to rent a trailer till you get something bigger.
   / Hauling A BX23 #3
I think I had read various threads that state that a 14 to 16 foot trailer would be ideal. If you are getting a mower you might have problems getting the deck on the trailer.
   / Hauling A BX23 #4
I moved mine with a 14' trailer and 16' would have been better. Just because it fits on, doesn't mean that it is going to be properly ballanced..... I suggest that you rent until you buy the proper one. Once you decide on the one the you want, have the dealer bring it to the tractor to make sure that it fits on properly. With the deck mounted on my tractor, it was a tight fit for everything on the 14'. Enjoy the new tractor and be safe....
   / Hauling A BX23 #5
It may be too late already, but I would say have them deliver it, rent a larger trailer or go buy the larger trailer today also.
I have a BX1800 that I do haul on my 6x10' trailer, but have to rest the loader on the back gate to get balance correct, and even then it doesn't leave a good angle for the tie down straps. You also have to consider the mower deck if you have one. Mine is 60" and fits on my 76" wide trailer with the shoot up.
Here is a pick of how tight mine is without a backhoe.
You don't want to take a chance with a $16K + piece of equipment and your life.
Enjoy the new unit, and I know how excitement can be /forums/images/graemlins/grin.gif
   / Hauling A BX23 #6
Wow. Haul a BX23 with a 5 x 8 ? When I do mine, I grab a 16' car trailer. If you decide to try it, you can bring the FEL up and over the front rail of the trailer/box and possibly tuck it in over the top. That stabilizes the tractor as well. Depends on your drawbar length and other factors if you can even do this.
Suggest you have the dealer assist in loading your tractor. They've done it way more than you have and showed me the FEL trick.
Do they offer delivery? I think that's the best way to get a new tractor, even if you have to pay $ 75 - $ 100 for it. Usually the dealer personnel will come along and you can have them show you the operating features for 30 - 45 minutes at your home. Get them to detach the backhoe/reinstall, and the FEL./reinstall. Much easier if someone shows you......
Good luck! You'll love this tractor. I sure do my BX22
-Duane
   / Hauling A BX23 #7
Just yesterday I was out pricing a trailer for my BX23. I was looking at a 20', dual axle, with brakes and ramps. I figured that a 20' trailer would allow me maximum flexibility to balance the load, plus haul two or three attachments (probably rotary mower, box blade, and tiller). Choices were a 7000 lb. capacity with brakes on one axle, or 11,000 lb. capacity with brakes on both axles. (Since the GVWR on my 5000 lb. truck is 12,000 lbs., I figure I'll go with the first one.) Any thoughts/comments on this setup?
As I think about this, I'm not sure how I'll get several 350 to 450 lb. implements on the trailer, especially if the BH is mounted on the tractor. Maybe I'm getting carried away here...
/forums/images/graemlins/tongue.gif
   / Hauling A BX23 #9
A 7000lbs. rated trailer should give you 5000lbs of payload capacity. That seems like plenty for your TLB with room left for 4- 500lb attachments. As you said that's also the max trailer size your truck is rated for.
   / Hauling A BX23 #10
Don't do it.
You just spent that much money for your tractor and on the 5'x8' trailer you could be spending more money on repairs before you get it home. I use a 16' (deck lenth) daul axle trailer with brakes on all four wheels for my bx-22. It will fit on a 14' but I like the extra room. have it delivered or rent the right trailer. Why take the chance.
Farmall A Tractor W/Belly Mower (NOT RUNNING) (A50774)
Farmall A Tractor...
2018 John Deere 460E Articulated Dump Truck (A52748)
2018 John Deere...
2015 Nissan Altima Sedan (A50324)
2015 Nissan Altima...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2006 Mack CT713 Granite T/A Galbreath Roll-Off Truck (A50323)
2006 Mack CT713...
