Grapple Has anyone used Unlimited Fabrications?
   / Has anyone used Unlimited Fabrications? #1
enterprisebbc
Ct
2008 CK35 Kioti
They have a nice log grapple for my CK 35 Kioti QA for $1300. They look reputable an the price is good. I want a single piston fork grapple for limbs and brush. Has anyone heard of em?
   / Has anyone used Unlimited Fabrications? #2
I have one of their root grapples and a set of loader forks. No complaints from me. I have had them for 8 years. ;)
Thanks. I didnt know if they were a fly by night. I'm going to order their single piston fork grapple for my CK35. He said 3 1/2 wks for del. Seems like a lot but guess I'll have to wiat. Did you pay shipping?
   / Has anyone used Unlimited Fabrications? #4
My parts were will called. I had another shipment coming my way from another source, so they picked them up for me.
So, to answer your question, no I did not pay them shipping.
thanks
   / Has anyone used Unlimited Fabrications? #6
I have not seen Unlimited Fabrications mentioned often on TBN, are you pleased (if you have received it) with your grapple? They are located relatively near me and I like the look of their HD Root Grapple.
Thanks.
   / Has anyone used Unlimited Fabrications? #7
Thanks.
I don't think that they build one small or light enough for most of the TBNers. I have been happy with my HD unit, but then I have 3900lb full height lift capacity.
   / Has anyone used Unlimited Fabrications? #8
Brian,
Thanks for your reply. Your 7520 has 25 more hp than my 340B and can surely handle almost anything! Am I correct that you have the Extreme Root Grapple? I am interested in their Heavy Root Rake and have some questions about its specs that are not answered on their web site. I have emailed Roger at Unlimited regarding fabrication of a Skid Steer Conversion unit and am going to call him today regarding the conversion and grapple.
I started a thread titled "Quick Attach and Grapple for Industrial Tractor?" and you and your company were named by member Piston as a possible source for the hydraulics upgrade needed for my conversion. Do you offer what I will need?
Thanks!:)
   / Has anyone used Unlimited Fabrications? #9
Brian,
Thanks for your reply. Your 7520 has 25 more hp than my 340B and can surely handle almost anything! Am I correct that you have the Extreme Root Grapple? I am interested in their Heavy Root Rake and have some questions about its specs that are not answered on their web site. I have emailed Roger at Unlimited regarding fabrication of a Skid Steer Conversion unit and am going to call him today regarding the conversion and grapple. I started a thread titled "Quick Attach and Grapple for Industrial Tractor?" and you and your company were named by member Piston as a possible source for the hydraulics upgrade needed for my conversion. Do you offer what I will need?
Thanks!:)
Actually they did not offer the Extreme Root Grapple 8+ years ago. Mine is the HD unit. I have diverter valves, but I can not match that $300 that was mentioned. I can get you my econo setup for about $400, normal system is $500. The only difference is that the valve is a bit rougher looking and not painted or plated. Not as refined of a finish as most of the diverters you see. This would be everything other than however you decide to mount it. You mount it, get me hose lengths and I get you hoses that fit your tractor.
   / Has anyone used Unlimited Fabrications? #10
Would you post on TBN or send by PM photos of the two systems you have. Would a diverter system work with my tractor's 21.5 gpm hydraulic flow rate?
Ultimate Fab 72" HD Root Grapple
  • Cylinders-2" bore and a 10" stroke
  • Opening - 36" H x 38" D
  • Steel - 1/2" Grade 50, 3" square tubing, 3" pipe
  • Line routing - Enclosed
  • Weight - 750 lb.
  • Tooth spacing - 9"
  • Recessed grease fittings -
  • Option - Cylinder rod covers
  • Colors - Black, dk. gray, JD green, Cat yellow, orange
  • Price - $1769.00
Skid Steer Conversion - No specs stated, will take about three weeks to fabricate. This one is about $225.00 less than a similar unit offered by another nearby fabricator.
Please let me know if this is built like your HD Grapple. I am a little concerned that the square tubes are 3" rather than 4".
Caterpillar 420F2 IT (A53314)
Caterpillar 420F2...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2008 41ft KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A55853)
2008 41ft KZ...
New Holland T2420 (A53317)
New Holland T2420...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2017 John Deere 30G Mini Excavator (A55851)
2017 John Deere...
