Grapple Has anyone used Unlimited Fabrications?
   / Has anyone used Unlimited Fabrications? #1
enterprisebbc
Ct
2008 CK35 Kioti
They have a nice log grapple for my CK 35 Kioti QA for $1300. They look reputable an the price is good. I want a single piston fork grapple for limbs and brush. Has anyone heard of em?
   / Has anyone used Unlimited Fabrications? #2
I have one of their root grapples and a set of loader forks. No complaints from me. I have had them for 8 years. ;)
Thanks. I didnt know if they were a fly by night. I'm going to order their single piston fork grapple for my CK35. He said 3 1/2 wks for del. Seems like a lot but guess I'll have to wiat. Did you pay shipping?
   / Has anyone used Unlimited Fabrications? #4
My parts were will called. I had another shipment coming my way from another source, so they picked them up for me.
So, to answer your question, no I did not pay them shipping.
thanks
   / Has anyone used Unlimited Fabrications? #6
I have not seen Unlimited Fabrications mentioned often on TBN, are you pleased (if you have received it) with your grapple? They are located relatively near me and I like the look of their HD Root Grapple.
Thanks.
   / Has anyone used Unlimited Fabrications? #7
Thanks.
I don't think that they build one small or light enough for most of the TBNers. I have been happy with my HD unit, but then I have 3900lb full height lift capacity.
   / Has anyone used Unlimited Fabrications? #8
Brian,
Thanks for your reply. Your 7520 has 25 more hp than my 340B and can surely handle almost anything! Am I correct that you have the Extreme Root Grapple? I am interested in their Heavy Root Rake and have some questions about its specs that are not answered on their web site. I have emailed Roger at Unlimited regarding fabrication of a Skid Steer Conversion unit and am going to call him today regarding the conversion and grapple.
I started a thread titled "Quick Attach and Grapple for Industrial Tractor?" and you and your company were named by member Piston as a possible source for the hydraulics upgrade needed for my conversion. Do you offer what I will need?
Thanks!:)
   / Has anyone used Unlimited Fabrications? #9
Brian,
Thanks for your reply. Your 7520 has 25 more hp than my 340B and can surely handle almost anything! Am I correct that you have the Extreme Root Grapple? I am interested in their Heavy Root Rake and have some questions about its specs that are not answered on their web site. I have emailed Roger at Unlimited regarding fabrication of a Skid Steer Conversion unit and am going to call him today regarding the conversion and grapple. I started a thread titled "Quick Attach and Grapple for Industrial Tractor?" and you and your company were named by member Piston as a possible source for the hydraulics upgrade needed for my conversion. Do you offer what I will need?
Thanks!:)
Actually they did not offer the Extreme Root Grapple 8+ years ago. Mine is the HD unit. I have diverter valves, but I can not match that $300 that was mentioned. I can get you my econo setup for about $400, normal system is $500. The only difference is that the valve is a bit rougher looking and not painted or plated. Not as refined of a finish as most of the diverters you see. This would be everything other than however you decide to mount it. You mount it, get me hose lengths and I get you hoses that fit your tractor.
   / Has anyone used Unlimited Fabrications? #10
Would you post on TBN or send by PM photos of the two systems you have. Would a diverter system work with my tractor's 21.5 gpm hydraulic flow rate?
Ultimate Fab 72" HD Root Grapple
  • Cylinders-2" bore and a 10" stroke
  • Opening - 36" H x 38" D
  • Steel - 1/2" Grade 50, 3" square tubing, 3" pipe
  • Line routing - Enclosed
  • Weight - 750 lb.
  • Tooth spacing - 9"
  • Recessed grease fittings -
  • Option - Cylinder rod covers
  • Colors - Black, dk. gray, JD green, Cat yellow, orange
  • Price - $1769.00
Skid Steer Conversion - No specs stated, will take about three weeks to fabricate. This one is about $225.00 less than a similar unit offered by another nearby fabricator.
Please let me know if this is built like your HD Grapple. I am a little concerned that the square tubes are 3" rather than 4".
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
CATERPILLAR D6R XL HIGH TRACK CRAWLER DOZER (A52707)
CATERPILLAR D6R XL...
Giyi 46" Mulcher (A53316)
Giyi 46" Mulcher...
Cummins 6-Cylinder Diesel Engine with Transmission (A55852)
Cummins 6-Cylinder...
2013 Ford F-150 Ext. Cab Pickup Truck (A55852)
2013 Ford F-150...
