Thanks Tom, I added the part numbers to that thread as well. BTW, I listed the rear lower arm pivot above, but that part is only used if you are removing the welded on attachment. Otherwise, you only need the two arm halves for each side and some pins and bolts. Stan
NY_Yankees_Fan said:Here is a link to adding the sway bars, this is a great addition to the BX if you use the 3 pt a lot, a lot quicker then the OEM turnbuckles.
http://www.tractorbynet.com/forums/attachments/12639-bx-2200-lift-arm-adjusters.html
