Chains Has anyone tried welding chain hooks onto a piranha tooth bar?
   / Has anyone tried welding chain hooks onto a piranha tooth bar? #1
MXBX
Maryland
Kubota B2601
First post but I've been enjoying the site a lot. The title pretty much says it all. I'm thinking of welding 2 hooks, one on each outer edge of my amazing new piranha tooth bar. Maybe I should call Harry???
   / Has anyone tried welding chain hooks onto a piranha tooth bar? #2
*looks confused* why would you want hooks on the tooth bar?
lots of folks welding and bolting on hooks to the back/top edge of the bucket for chains, but the tooth bar?
   / Has anyone tried welding chain hooks onto a piranha tooth bar? #3
Curious why you would want them on your TB and not on the bucket itself. Seems like you'd be asking a lot from one grade 5 or even grade 8 bolt at each end of the TB.
You're probably right. I've been using the tooth bar a lot and was recently digging out a weeping cherry tree and thought having the hooks at the ends would be handy for pulling out the last few roots. It also seems like the steel of the TB is thicker and stronger than the bucket.
   / Has anyone tried welding chain hooks onto a piranha tooth bar? #5
Hi welcome to TBN.. I like the others am thinking this might not be such a good idea. putting pulling stress on the Pirhana tooth bar would be a big no no for me.
Thanks guys! It's why I asked.
   / Has anyone tried welding chain hooks onto a piranha tooth bar? #7
Well, most folks "beef up" the uppper lip of the bucket with some angle iron. Some put it across the whole thing, but some just put a 3 or 4 inch piece of 3/8 angle welded to the top and then down to strengthen it. Then weld the hook to the top of that.
   / Has anyone tried welding chain hooks onto a piranha tooth bar? #8
I agree with the others, weld them to the bucket not the toothbar.
   / Has anyone tried welding chain hooks onto a piranha tooth bar? #9
I bolted on my Ken's hooks with backing plates to the top of the bucket on each side, inline with the hydraulic cylinders. I then run a chain between the two hooks to spread the load evenly and chain up whatever I need to the load chain. To me, hooks on the bucket like this are a necessary requirement, as is 4WD, rear differential lock, HST, grapple bucket, 3PH draft control and extra remotes- front and rear.
   / Has anyone tried welding chain hooks onto a piranha tooth bar? #10
^^ THIS
he'll likely quickly be able to tell you exactly why you should or should not try this.
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
Generac 2000 Generator (A50774)
Generac 2000...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
