Has anyone had problems yanking stumps out with an eHydro?
   / Has anyone had problems yanking stumps out with an eHydro? #1
Bspring
SC
I occasionally will use a logging chain connected to the back of my 3320 to pull a stump up. Has anyone had any transmission problems related to this? Sometimes a little momentum is required.
   / Has anyone had problems yanking stumps out with an eHydro? #2
If you were yanking, then that is not good for the equipment. Things break. I can imagine all kinds of problems that will/can result from yanking, if that is what you mean.
Steady pull is the way, and if it doesn't work figure out another way to loosen the object.
Is the tranny acting up now?
   / Has anyone had problems yanking stumps out with an eHydro? #3
is an eHydro another name for a hydrostatic transmission? I've not actually had any problems with stump removal. I have found the drive is tight enough to stall the engine if the stump won't move - much like forgetting to push in the clutch when stopping a regular stick shift.
   / Has anyone had problems yanking stumps out with an eHydro? #4
watch out for snapping whether chain or cable you are doing this with and them then becoming a whip that can kill.
   / Has anyone had problems yanking stumps out with an eHydro? #5
A tractor with structural aluminum cases and final drive housings is not the choice to "yank" stumps. While those cases are strong, that's not the type of shock the were designed for.
In the end, it's your tractor and wallet
   / Has anyone had problems yanking stumps out with an eHydro? #6
For the few stumps I've removed with my 3520 with eHydro, I typically run out of traction before anything else. Best to loosen the stump as much as possible prior to pulling. Personally, I would not risk jerking the stump. Good luck!
   / Has anyone had problems yanking stumps out with an eHydro? #7
I cut the stump down to 6" tall, then grind to several inches below the ground using my stump grinder, the rest will rot away.
In instances in which I have to jerk on the load such as using my 4x4 truck to get someone out of a ditch when conditions are so icy that I would never achieve forward motion from a dead stop I use my 3" wide recovery strap.
   / Has anyone had problems yanking stumps out with an eHydro? #8
My neighbors employee attempted yanking on chain with JD 5603 cab tractor(99HP) attempting to pull a rubber tired loader of being stuck. Chain broke taking out rear window,LH door & windshield narrowly missing tractor operator. Only thing that cures some ignorant things is prior experience or death.
   / Has anyone had problems yanking stumps out with an eHydro? #9
We had a farmer in this area die that way, buried the clevis in his back, and he bled out. Nothing anyone could do to save him.
   / Has anyone had problems yanking stumps out with an eHydro? #10
Depends on the stump I guess. My 3320 eHydro’s not stout enough to do a lot of yanking on anything substantial and I also usually run out of traction before horsepower.
6' Fork Extensions (A56469)
6' Fork Extensions...
UNUSED WOLVERINE SB-12-72W 72" HDY SCREENING BUCKE (A57193)
UNUSED WOLVERINE...
1992 AM General M998 HMMWV 4x4 Humvee Truck (A55852)
1992 AM General...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
BOX OF (2) GENUINE MOPAR SIDE STEPS (A57192)
BOX OF (2) GENUINE...
