Has anyone Ever Made A Pipe Blade Edge So Their Bucket Doesn't Dig In For Plowing
   / Has anyone Ever Made A Pipe Blade Edge So Their Bucket Doesn't Dig In For Plowing #21
I tested this concept (which I read about here) using a length of pvc pipe that I ran through my table saw.
It does work very well at keeping the gravel on the driveway though, highly recommend. For what it’s worth, I got four plowings out is the PVC before it shattered.
I did the same with the blade on an ATV. It worked well for the first few plowings of the season, which was all I really needed for. Cutting the slot on a table saw was a little scary, and it was kind of a PITA to put on.
Never really needed one for the loader on the tractor (which I use for bigger snowfalls than the ATV can handle) since I can tilt the bucket back a few degrees.
   / Has anyone Ever Made A Pipe Blade Edge So Their Bucket Doesn't Dig In For Plowing #22
For sure edge tamers are the way to go.
I diy'd mine and am super pleased with the results.
Also made me a set of oversized skid shoes for my blower and I never have gravel to rake back.
OK, I DIY and have a welder so that helps.
   / Has anyone Ever Made A Pipe Blade Edge So Their Bucket Doesn't Dig In For Plowing #23
Yep, works best for when the ground isn't frozen. We get quite a few heavy wet storms where I need the full weight of the plow on the ground, if I angle back even a bit the blade will ride up over the snow. That's why I used the pipe. When I get a good packed base on the driveway the pipe can come off.
It's all irrelevant for me now that I plow with the truck. My doggo enjoys plowing too, so she rides *******.
2015 Hyundai Sonata Hybrid Sedan (A53424)
2015 Hyundai...
(2) SQUIRREL CAGE FANS (A54757)
(2) SQUIRREL CAGE...
2007 INTERNATIONAL 9400I TANDEM AXLE DAY CAB (A56129)
2007 INTERNATIONAL...
Step Ladder (A47477)
2016 Infiniti Q50 AWD Sedan (A55758)
2016 Infiniti Q50...
