Has anyone Ever Made A Pipe Blade Edge So Their Bucket Doesn't Dig In For Plowing
   / Has anyone Ever Made A Pipe Blade Edge So Their Bucket Doesn't Dig In For Plowing #21
I tested this concept (which I read about here) using a length of pvc pipe that I ran through my table saw.
It does work very well at keeping the gravel on the driveway though, highly recommend. For what it’s worth, I got four plowings out is the PVC before it shattered.
I did the same with the blade on an ATV. It worked well for the first few plowings of the season, which was all I really needed for. Cutting the slot on a table saw was a little scary, and it was kind of a PITA to put on.
Never really needed one for the loader on the tractor (which I use for bigger snowfalls than the ATV can handle) since I can tilt the bucket back a few degrees.
   / Has anyone Ever Made A Pipe Blade Edge So Their Bucket Doesn't Dig In For Plowing #22
For sure edge tamers are the way to go.
I diy'd mine and am super pleased with the results.
Also made me a set of oversized skid shoes for my blower and I never have gravel to rake back.
OK, I DIY and have a welder so that helps.
   / Has anyone Ever Made A Pipe Blade Edge So Their Bucket Doesn't Dig In For Plowing #23
Yep, works best for when the ground isn't frozen. We get quite a few heavy wet storms where I need the full weight of the plow on the ground, if I angle back even a bit the blade will ride up over the snow. That's why I used the pipe. When I get a good packed base on the driveway the pipe can come off.
It's all irrelevant for me now that I plow with the truck. My doggo enjoys plowing too, so she rides shotgun.
2015 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2015 GENIE...
16FT box truck (A53424)
16FT box truck...
MILLERMATIC 252 W/LEADS (A55745)
MILLERMATIC 252...
2018 FORD F-150XL EXT CAB TRUCK (A52706)
2018 FORD F-150XL...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
2007 Ford F-150 Ext Cab Pick-up Truck (A53422)
2007 Ford F-150...
