Has anyone else done this
/ Has anyone else done this #1
stowester
Vermont
Big mess on my first oil change......
1) Put my pan under one side of the oil pan, removed the plug.
2) Moved the pan over to the other side as far as I could and removed that plug
3) Centered the pan under two plugs and wondered why it was draining slow
4) Removed the dip stick to vent the case to see if that would allow it to drain faster
5) Swore as oil overshot the pan on both sides and made a mess
6) Laughed to myself and thought I should pole the folks on TBN to see if I was the only one to have done it.
Dean
/ Has anyone else done this #2
Nah, I'd never do anything like that . . . at least not more than 2 or 3 times.:D
/ Has anyone else done this #3
I wish I could write more but I'm worried over the oil dripping off my shirt sleaves affecting the computer!
/ Has anyone else done this #4
Dean
Guess you need to invest in a bigger pan:D
/ Has anyone else done this #5
aaaaahhhhhhhhh, yea :eek:
Our tractor toys tend to hold a bit more oil then our cars and lawn mowers :rolleyes:
I keep a supply of latex gloves around for ALL my maintenance needs. Between the grease and oil, I'm a mess :D
/ Has anyone else done this #6
Dean
This is what I bought at TSC to drain all my fluids into when I did the 50 hour service.
Feeder Pan; 3 gal Size; 1/3 Bushel Type; Black Color; Rubber, Fiber Reinforced Material; For Ideal for General and Industrial Use; 1 dz Bundle; Bag
Wide low rubber pan. Specially designed for hogs and other animals. Ideal for general and industrial use. Real rubber, fiber reinforced. Crack and crush resistant, absorbs shocks. Flexible at low temperatures. Immediately bounces back to shape. Long lasting usefulness.
Tractor Supply Company - 1/3 Bushel Feeder Pan (3 gal)
/ Has anyone else done this #7
I had a similar experience with the hydro fluid change. Removed the drain plug and the fluid was gulping/spattering around. I then pulled the dip stick to see if this would help with the gulping and fluid shot out all over the place. Big lesson learned.
/ Has anyone else done this #8
Welcome to the oily rag club:)...when you decide to drain/flush the radiator you'll be ready now. ;)
/ Has anyone else done this #11
I use a 3 gallon plastic bucket as a drain pan ... fits under ok and has a bale for carrying / emptying....
/ Has anyone else done this #12
I use a sheet rock pail for the engine oil.
When I do the hydro fluid I use a sheet rock pail under the first plug, then I move it to the second plug and use the drain pan pictured elsewhere in this thread under the first plug, then I rotate the pale to the third plug, close the first and put the pan under the second. I use the pail when I unsrew the filters also. I tie a rag around my wrist as I pull the drain plug out, that usually stops the old up the arm trick.
I had really good luck at my 50 hour service, didn't spill a drop anywhere until I went to pour the hydro fluid in from a 5 gallon pail, then it turned into a horror show, I ended up transfering it to a one gallon container and then into the funnel, that made equally as big a mess. But as much mess as I made I know I saved a ton of cash.
/ Has anyone else done this #13
Nice story:) thanks
I was really smart the other day and installed a drain on the oil pan for auto transmission on the family Jeep GC. I was sick of pouring it all over myself while removing the pan for the filter change.
My old man was over here in Virginia and I wanted to quickly change the filter and ATF. I admit I was showing of a bit too :) I used my super duper drain; drained all of the ATF, grabbed airgun and unscrewed all the bolts but two, dropped the air gun, using hand wrench I took out the last two bolts and started to take the empty pan out. Well, empty - I poured all the ATF left in the pan on my head and in my eyes. Got a good gulp of it too:) The drain was little bit above the bottom - enough to leave a quart of liquid.
You would not believe, how bad it tastes and how hard it is to wash it out of your eyes :D
/ Has anyone else done this #16
For you BX'ers out there, Lowes sells a large, black plastic tub that fits PERFECT between the rear tires and will catch everything. It looks kind of like a busboy tub, costs $5.
/ Has anyone else done this #17
Last time That ever happens! LOL
Don
2023 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2023 CATERPILLAR...
2023 WACKER NEUSON G70 TOWABLE GENERATOR (A63276)
2023 WACKER NEUSON...
2020 HYDREMA 922G HM ARTICULATING DUMP TRUCK (A65053)
2020 HYDREMA 922G...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2012 Chevrolet Equinox AWD SUV (A64557)
2012 Chevrolet...
2020 FREIGHTLINER CSCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2020 FREIGHTLINER...
