Has anyone built.........
/ Has anyone built......... #1
Unclelevi
Dassel, Minnesota
JD X540, JD 1250
Have any of you built a bucket level indicator for your tractor ? If so, I'd like to see it.
/ Has anyone built......... #2
I would encourage you to use the search function to explore this topic. It has been well covered here with several dozen threads. I made one for my tractor, but it does not differ much from what others have shown in their threads. Here are the first 5 search results I found.
/ Has anyone built......... #3
My Ford 1715 had one on it, but I think I didn't get it reinstalled after I removed the bucket a while ago.
Simply a tube on the upper loader arm, and a piece of metal that attached to the bucket. I wasn't using it. It probably needed multi colored tape paint to indicate important angles.
/ Has anyone built......... #4
Several of my tractors had them, I never used them as it was easy to see when bucket was level
/ Has anyone built......... #5
I built one for my BX2230, out of parts and material I had on hand. Works great.
/ Has anyone built......... #6
Yes I built one, yes it was a good addition there are times I need to have a precise angle on bucket to just skin the work....
Search feature can be your friend..... Mine is somewhere in all the posts....
/ Has anyone built......... #7
/ Has anyone built......... #9
Here are pics of what's on my loader.
/ Has anyone built......... #10
Most BLI's get set to show the bucket position when lowered in the "let's scrape up the manure" position. I made one from some rod and mini Heim joints for the L3200 because it had nothing from the factory. You could come up with some crude system of marking it for other positions and develop a feel for the in-between stuff. The adjustment for level changes with bucket height.
With a little time to think it over it wouldn't be too difficult to make something better than this one that I whipped up a while back for my forks. It's a round magnet with a copper bar and wire that can swing freely. There's a strip of truck tape (aka conspicuity tape) on the edge so it can be calibrated to have the wire between the red and silver when level and stuck on the side of the headache rack frame of the forks. That way it indicates level regardless of the bucket height without getting too technical.
Here's a pic of it stuck on a piece of sheet metal.
/ Has anyone built......... #11
Clever
