has anyone built a safety cage cab?
   / has anyone built a safety cage cab? #1
RancherSam
Hays County, TX
Case IH JX95 4x4
Has anyone build a safety cage cab? One that's stout and has a good structure overhead for say falling debris like branches and such? I'm still getting the pieces together for my custom cab, and am wondering if I should really build up the top. I'm not in a heavily wooded region now but will be moving to one soon, and thinking safety first.
   / has anyone built a safety cage cab? #2
Do a search for FOPS, there is lots of discussion on this very topic.
It stands for Falling Object Protective Structure
   / has anyone built a safety cage cab? #3
GR Mfg built my FOPS for my Deere 4720, then I had a local welder make me a forestry cage. I need both for using my tree cutter. It was much cheaper then a trip to the ER with a fracture.
   / has anyone built a safety cage cab? #4
turkeyman, we need pics! Aways post pics! Everyone likes pics! Hope to see your pics!
Sincerely, Dirt
   / has anyone built a safety cage cab? #5
I never can post pictures send me a PM with your email address and you can post if you like.
Sorry
   / has anyone built a safety cage cab? #6
Do as I do Turkeyman, create a photo album on Google or any of the other photo sharing sites. I like Google because it's simple, it works, and it isn't loaded down with ads and other superfluous junk.
Yes, we want pictures!
   / has anyone built a safety cage cab? #7
   / has anyone built a safety cage cab? #8
I email them to Dirt and will try that Google posting thing.
   / has anyone built a safety cage cab? #9
Turkeyman, thanks for the pics. If I knew how to post the pics from an email to this site I would post them for you. Neat set up.
Sincerely, Dirt
   / has anyone built a safety cage cab? #10
Here's mine. Red Rocker was kind enough to send me pics of his, and I modified his ideas to work for me.
The supports are 1 1/2" sq. I bent them with a pipe bender. HF 12 ton. I was surprised that it did the job, but no problem.
The top is heavy alum. Because I had it. There is expanded metal on the rear face, and some on the front. I am going to make up a piece to put on the right side - at times for bush hoggin'. I like to get close to the edges.
The front supports are pinned on, and the rear is attached with the ball connectors such as used on top links. I can fold the whole top back and drive it in the garage if I have to, as shown in the pic. attached.
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2013 Nissan Pathfinder Multipurpose Vehicle (MPV) (A51694)
2013 Nissan...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A52472)
2008 JACK COUNTY...
378740 (A51572)
378740 (A51572)
