Has anyone built a log forwarder?
/ Has anyone built a log forwarder? #1
jimgerken
Minnesota
John Deere 3720
My neighbor wants me to help him build a log-forwarder. I am open to lots of input on what is needed, what works, projects you've done, etc. He owns a large tractor-type backhoe and currently drags the logs up out of the woods with that. But they get dirty doing that, and of course the trails get a bit screwed up by the dragging logs. If he had a simple forwarder it would be better for a lot of reasons. He owns a sawmill, and burns wood to heat his shop and house, on his 350 acres wooded. So the wood harvesting continues.
My first thoughts were to add a hitch to his backhoe in some fashion, so he could pull a two wheeled trailer, built of an old manure spreader (two wheel trailer with very heavy duty axle with large wheels and tires). Then add a hyd grapple to replace his BH bucket, so he can load his own logs and puill them home, all with one rig, and one operator, and one trip. That's as far as I have thought thru it, then I thought of you guys...
/ Has anyone built a log forwarder? #5
I like the cart idea.
To keep the cost down, do you think log tongs would work attached to the backhoe with a short chain? Maybe 2 of them would keep the swaying down to a minimum?
Like these.
Log Tongs
/ Has anyone built a log forwarder? #6
I do it like Rob does with the hoe but the log keeps hanging up and brakes loose and fly's toward the hoe I keep thing about a tugger chain pulling and tongs off hoe for hight
tom
/ Has anyone built a log forwarder? #7
This trailer is for an ATV, but could be "upsized" depending on the tractor matched to it. It's not a forwarding trailer per say, but it has many good design features.
Welcome to the MUT Trailer Company
/ Has anyone built a log forwarder? #8
I have been thinking of making one for a while now. I made a smaller version a few years ago and would use the same design but increase the size and add brakes. As far as the loader goes you may be able to use the back hoe to load the trailer or a small grapple could be purchased and added to a home grown trailer.
There is a picture of the trailer showing how the walking beam suspension works going over a bump in the road. I have loaded this trailer with over 3,000 pounds of wood without any problems. The next generation will have a removable box for smaller material and bunks and stakes for logs.
Randy
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
Hedge Posts (A65640)
2008 Case IH JX80 Loader Tractor (A66285)
2008 Case IH JX80...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
2020 Can-Am Commander XT 1000 R (A62679)
2020 Can-Am...
(4) Drive Tires off Kinze 3000 Planter (A65640)
(4) Drive Tires...
