Has anyone built a brush rake?
   / Has anyone built a brush rake? #1
DDouglas
   / Has anyone built a brush rake? #2
Possibly, but I do not fully understand US English. Please elaborate on what it is, how big a machine will pull it, and the nature of the "brush" ie small, or as in Oz, "bloody great trees". Old McDonald.
   / Has anyone built a brush rake? #3
Like this?
   / Has anyone built a brush rake? #4
No, but I need one like that really bad for my D21
on edit: That looks like its on a D21!!!
/forums/images/graemlins/shocked.gif
   / Has anyone built a brush rake? #5
i built this rake for our IH TD9 dozer using some thick steel plate to cut the teeth outa and the rest were parts of a forklift mast. took a few nights of welding after all the pieces were cut and tacked together, but it works great
   / Has anyone built a brush rake? #6
I like these - could you describe how you mounted? What are the contact points on the rake?
Really looks good.
   / Has anyone built a brush rake? #7
Here is one that I made out of solid rod and well casing for my dozer. Relatively light duty but it shows the principles you are looking for.
That's 7018 from a lincoln tombstone AC 225 stick welder. I realized after this project how important good surface prep is at the ground clamp and at the weld. I also now fab with 6013 for prettier welds and moisture tolerance.
   / Has anyone built a brush rake? #8
Here is mock up on the dozer.
   / Has anyone built a brush rake? #9
And here is the attachment as you asked.
Note the hinge allows the rake to flip up as you backblade. Also the hinge style allows the rake to be picked up without pinning it on.
I modeled the rake after the early D21 like post. Spacing was 10" with 12" of tine length. It worked great until I hooked the outer tines on stumps and then they snapped off. It isn't a stumping rake but a raking rake.
   / Has anyone built a brush rake? #10
Here is a link to what might be considered a brush rake for a small tractor.
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53473)
2019 New Holland...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2025 CFG Industrial 680 (A50123)
2025 CFG...
TMA (A49461)
TMA (A49461)
UNUSED Rustproof Galvanized Wire Mesh Rolls (A53117)
UNUSED Rustproof...
