Has anyone built a brush rake?
   / Has anyone built a brush rake? #1
DDouglas
   / Has anyone built a brush rake? #2
Possibly, but I do not fully understand US English. Please elaborate on what it is, how big a machine will pull it, and the nature of the "brush" ie small, or as in Oz, "bloody great trees". Old McDonald.
   / Has anyone built a brush rake? #3
Like this?
   / Has anyone built a brush rake? #4
No, but I need one like that really bad for my D21
on edit: That looks like its on a D21!!!
/forums/images/graemlins/shocked.gif
   / Has anyone built a brush rake? #5
i built this rake for our IH TD9 dozer using some thick steel plate to cut the teeth outa and the rest were parts of a forklift mast. took a few nights of welding after all the pieces were cut and tacked together, but it works great
   / Has anyone built a brush rake? #6
I like these - could you describe how you mounted? What are the contact points on the rake?
Really looks good.
   / Has anyone built a brush rake? #7
Here is one that I made out of solid rod and well casing for my dozer. Relatively light duty but it shows the principles you are looking for.
That's 7018 from a lincoln tombstone AC 225 stick welder. I realized after this project how important good surface prep is at the ground clamp and at the weld. I also now fab with 6013 for prettier welds and moisture tolerance.
   / Has anyone built a brush rake? #8
Here is mock up on the dozer.
   / Has anyone built a brush rake? #9
And here is the attachment as you asked.
Note the hinge allows the rake to flip up as you backblade. Also the hinge style allows the rake to be picked up without pinning it on.
I modeled the rake after the early D21 like post. Spacing was 10" with 12" of tine length. It worked great until I hooked the outer tines on stumps and then they snapped off. It isn't a stumping rake but a raking rake.
   / Has anyone built a brush rake? #10
Here is a link to what might be considered a brush rake for a small tractor.
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2005 Ford Focus Sedan (A51694)
2005 Ford Focus...
2021 Ford Explorer SUV (A51694)
2021 Ford Explorer...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53473)
2014 Doyle Dry...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
