Has any one considered a Japanese Mini?
   / Has any one considered a Japanese Mini? #81
I have a Suzuki, forgot the year but it's in the 90's. It's a zippy little thing, will climb a near vertical hill. It's tricky getting used to the left handed gear shifting, but not too much of a problem.
What I don't like is the leg room... it's made for small Japanese folks, not typical sized Americans. I'm 5'11" and can't stand to drive it for even short periods of times.
Will probably try to sell it soon, have my sights set on the Kubota 1140.
   / Has any one considered a Japanese Mini? #82
The new ones do not smoke ... used if they are a little tired, they may.
New are 0 detectable emissions 3'+ from exhaust pipe
   / Has any one considered a Japanese Mini? #83
The '90s Suzuki you have has the tightest cab. Subaru has the largest.
I'm 6'1" and don't have a problem in the Suz., although I would not want to take it for a 100 mile trip.
The '99 and newer trucks have a larger cab but they still are tight for us larger Americans. Most of the world is not as large as we are.
dan
woodysminitrucks.com
   / Has any one considered a Japanese Mini? #84
Build finally completed. 4' or 5' wide models available, 1000 lb. dumping capacity (still have to add a few safety stickers and a different flow control valve)
Load, back up tight to a roll-off, push the button, dump, lower unit, and done
dan at woodysminitrucks
   / Has any one considered a Japanese Mini? #85
Suzuki and other manufactures make autos and vans on the same chassis as the trucks
   / Has any one considered a Japanese Mini? #86
Mitsubishi Mini Cab with the extended cab option. This option shortens the box to 5'. They are a little pricey but competitive with a comparably equipped side by side.
Dan EXP AUTO List
   / Has any one considered a Japanese Mini? #87
One available locally.. Notice the tank treads!!! Apparently they are quite rare. Over 10k for this one
2014 Ford F-150 4x4 Crew Cab Pickup truck (A55973)
2014 Ford F-150...
294 (A52706)
294 (A52706)
2017 Bobcat T770 Compact Track Loader (A56435)
2017 Bobcat T770...
Case Backhoe (A55973)
2017 John Deere 35G Mini Excavator (A55973)
2017 John Deere...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
