Harrow for pasture use
/ Harrow for pasture use #1
Dragonpharm
Pekin, IL
Mahindra 1538 with backhoe, Massey Ferguson 156 gas
I'm looking into buying a drag harrow mainly to be used to spread out manure and refresh pasture areas. Wondering if anyone has had good results with an ATV harrow? I'm considering one small enough to be pulled by a Kawasaki Brute Force 750 partially because my youngest would like to use it to smooth out inside a round pen I'm addition to my usage for spreading out manure. She made a good point that the ATV can fit through the round pen gate without taking a panel loose to make room for a tractor. I believe a small harrow should work to spread out manure and "refresh" pasture. Plan is to rotate horses and donkeys off of pastures to let them regrow and keep the animals from making everything a mud pit.
Any suggestions, comments, or ideas for something better?
/ Harrow for pasture use #3
You may have to add little weight on drag harrow.
/ Harrow for pasture use #4
I use this one for parking lot and driveway maintenance. It’s very well built and they should offer a size for your intended use.
Wingfield American Harrow - American Steel. American Labor. American Quality.
When/if I use it with my Mahindra 1538 I would probably not drop the backhoe to attach it. If the ATV could pull it there wouldn't be a reason to. Also, the ATV may just have the job by itself. With mud tires I put on for snow plowing it is very good at towing and things and has a lot of traction.
/ Harrow for pasture use #8
View attachment 724697View attachment 724698
I also use a Wingield framed/lift Chain Harrow. Framed/lift Chain Harrows mount on a tractor's Three Point Hitch.
With 8 - 10 acres in pasture an investment in a tractor-mounted Chain Harrow probably makes good sense.
WINGFIELD: Wingfield ED3PT57 (TPH/Framed/Lift) --- CHAIN HARROW ---
------- 0 ------​
I believe a small harrow should work to spread out manure and "refresh" pasture. Plan is to rotate horses and donkeys off pastures to let them regrow and keep the animals from making everything a mud pit.
A Chain Harrow will spread manure, which will provide 5% to 10% of the nutrition grazed grass requires for max production. If pasture load will be more than a few animals, grass with require fertilizer to compensate for organic matter animals eat.
No Chain Harrow will correct compaction from horse and donkey hooves. For compaction relief on 5 to 10 acres you need an All Purpose Plow / Field Cultivator.
ALL PURPOSE PLOW: Dirt Dog - All Purpose Plow / Field Cultivator REVIEW + PICTURES
VIDEO: https://www.youtube.com/results?search_query=tractor+all+purpose+plow
Mahindra 1538 Dimensions​
Mahindra 1538 Weight
Shuttle ROPS: 3186 lbs
1445 kg
Hydro ROPS: 3175 lbs
1440 kg
Hydro cab: 3627 lbs
1645 kg
With ROPS, 4-WD and liquid filled rear tires your Mahindra 1538 will pull a 4-tine All Purpose Plow to full depth through moist soil for sure. With air-inflated tires it may not pull 4-tines to full depth.
With a cab and 4-WD your Mahindra 1538 SHOULD pull 5-tines to full depth, but not for sure.
/ Harrow for pasture use #9
For spreading manure look at a Tedder or Side Delivery rake. Either one should break up manure and spread it pretty evenly. Might also dethatch/aerate the pasture And help smooth it out.
/ Harrow for pasture use #10
Chain harrow has several ground engagements options depending on how you pull it. Makes a difference how much power to pull. Getting a small one for your atv a good option. Take awhile to cover 5 acres. Helps with pasture and animal health. Not a substitute for subsoiler, pasture renovator, lime or fertilizer. Local county farm extension love to help and advise how best to utilize land.
/ Harrow for pasture use #11
I used to pull my harrow with the RTV900. It worked fine as long as you could keep moving forward. You aren't going to want to wrestle with it all the time as they are heavy. The biggest issue I had was that I couldn't lift it to get into spots and pull forward. I ended up mounting it to a frame (like the one shown above) and can now pull it with the tractor 3 point. It also makes clearing debris faster if you can pick it up. The RTV's trans temps would rise from me pulling it in the most aggressive position over time so I always kept an eye on it.
excavator trenching bucket- one bucket per lot (A63689)
excavator...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2005 Freightliner Tropi-cal T396 39ft. Class A Motorhome (A61574)
2005 Freightliner...
2009 Kubota M108S (A64119)
2009 Kubota M108S...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
