Rake Harley Rake
/ Harley Rake #1
BX24FOR5
Wi
Kubota BX24
I'm looking to purchase a used Harley Rake Preferable 48".
For Kubota BX24.
Thankyou
/ Harley Rake #2
Good luck; hard to find, if you do find one; usually junk or newer and high priced.
/ Harley Rake #3
I never knew that Harley made a 4 ft model power rake but apparently they do :eek:
http://www.taletattachments.com/files/tm4brochure.pdf
I have never seen one of the smaller ones for sale used. The used ones in my area are generally the skid steer type.
Brady Barlow has some 6ft tractor models for sale on his used page. He indicates 3 in stock but they would be to large for a BX24.
Used Kubota Tractors
/ Harley Rake #5
I used to own one in the 90's and really liked how it worked. You could take an inexperienced operator and really clean up his work and it made planting much easier. Last year when we build our house I rented a tractor mounted one and it worked great. Only problem is that we have rocky soil and it caused us to have to rake up a ton of stones, enough here in Northeastern Pa. that I was able to run a second driveway from the road to the back of my yard. Saved on the cost of modified.
A Harley rake is great at clearing areas with grass and weeds since it windrows it to the side. If not needed I would prefer a rockhound. You can actually make the planting look just as good if it's you who's running the machine. You learn how to adjust when running it only thing is some people only like going forward.
With either you'll be happly but I think a 48" unit is a little small since your running it at an angle, makes it hard to cover your tracks, but that's only my opinion.
/ Harley Rake #6
Have you thought about renting.All of the used harley or finn rakes I have seen at auctions were either totaly worn out or if in good condition went close to new price. Also if you rent you can try different sizes to see what works with your tractor.
Bill
/ Harley Rake #7
Just saw a harley rake sell on ebay for around 1800. From the pictures you could see that it had seen better days. The drum was worn almost smooth.
2025 LandHonor HPF-11-3000G 48in Hydraulic Adjustable Forks and Frame Skid Steer Attachment (A60352)
2025 LandHonor...
CAT 225BLC Excavator (A61166)
CAT 225BLC...
1267 (A62130)
1267 (A62130)
2023 GMC 1500 Sierra Elevation Crew Cab 4x4 Pickup Truck (A60352)
2023 GMC 1500...
1999 Sterling L9513 Tri-Axle Roll Off Truck (A59230)
1999 Sterling...
PT 1000 Gallon Nurse Tank (A62177)
PT 1000 Gallon...
