Hard to open hood on my CK 25--found solution!
   / Hard to open hood on my CK 25--found solution! #1
Hoffie
Southcentral Pa
Kiota CK25
I could not open the hood without using a wrench as leverage and even that was hard. I tried using grease on the upper latch bar and I can open it by hand. The upper latch bar is attached to the hood.
   / Hard to open hood on my CK 25--found solution! #2
It also helps if you push down on the hood while releasing the latch.
I had a friend push down on the hood while I tried to release it and I still had to use the leverage. Then grease solved my problem.
2003 Big Tex 10PI...
PALLET FORKS (A58214)
72in Dual Cylinder Brush Grapple Skid Steer Attachment (A56857)
72in Dual Cylinder...
2023 John Deere 333G for Parts (A56435)
2023 John Deere...
2012 PROCO KILL TRAILER (A58214)
2012 PROCO KILL...
Toro z turn (A56857)
