Hard to open hood on my CK 25--found solution!
   / Hard to open hood on my CK 25--found solution! #1
Hoffie
Southcentral Pa
Kiota CK25
I could not open the hood without using a wrench as leverage and even that was hard. I tried using grease on the upper latch bar and I can open it by hand. The upper latch bar is attached to the hood.
   / Hard to open hood on my CK 25--found solution! #2
It also helps if you push down on the hood while releasing the latch.
I had a friend push down on the hood while I tried to release it and I still had to use the leverage. Then grease solved my problem.
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
16ft x 8ft Flat Bed (A57454)
16ft x 8ft Flat...
air compressor (A55758)
air compressor...
LOT: (9) Wheel Loader Shanks (A59076)
LOT: (9) Wheel...
