Hard to open hood on my CK 25--found solution!
   / Hard to open hood on my CK 25--found solution! #1
Hoffie
Southcentral Pa
Kiota CK25
I could not open the hood without using a wrench as leverage and even that was hard. I tried using grease on the upper latch bar and I can open it by hand. The upper latch bar is attached to the hood.
   / Hard to open hood on my CK 25--found solution! #2
It also helps if you push down on the hood while releasing the latch.
I had a friend push down on the hood while I tried to release it and I still had to use the leverage. Then grease solved my problem.
Year: 2012 Make: Hyundai Model: Elantra Vehicle Type: Passenger Car Mileage: 123,909 Plate: Body (A50324)
Year: 2012 Make...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
Steel Flatbed (A50515)
(3) UNUSED FUTURE JUMPER CABLES (A51243)
(3) UNUSED FUTURE...
