Hard time with new tractor
   / Hard time with new tractor
I. My 3215 HST dynos out with 34HP. My tractor ballasts out at 5000lbs.
Something to consider, but then where do you stop? :confused3:
Good luck with your research. ;)
Brian I thought the 3215 was an early counterpart of the modern 16 series. What do you use to get your tractor to 5000lbs? Also, is your tractors speed regulated by first the column mounted stick and then the pedal? The pedal would not allow the tractor to reach its highest rpm in any range. You had to first adjust the stick for more rpm. Is this the way your Mahindra works?
   / Hard time with new tractor #142
NO
Yes, the 15 series were the pre 16 series machines and the later 15 series such as mine were a bit more refined than the earlier models. The first 16 series like mine were called a 3316 and the ONLY difference were the decals. They later went on to change some aluminum parts over to cast iron.
5000lbs = the tractor, loader, heavy implement and all 4 tires being loaded. It is recommended in the owners manual that the gross weight not exceed 5000 lbs. I would guess that the newer 16 series tractors allow for more weight with the aluminum parts being changed out for cast iron pieces and that the loader has a higher lifting capacity.
I can change speed either with the throttle or the go pedal. It does not have to be done in any sequence. Now of course if you were under a heavy load, you will not go any faster by pushing further down on the go pedal. As others have mentioned, high range is for transport, I have no problem being able to move at top speed up hill. How steep I don't really know. :ashamed: All I know is that out property has a 140' elevation difference.
I hope that at least some of this can help you in some way. ;)
Any updates?
No. Going back to he dealer tomorrow and with hydro operating instruction notes gleaned from the friendly people here, will see if the hydro on this particular tractor is a fit for me.
Just came back from the dealer and bought the geared 3016 with ags. I tried the 3016 hydro for almost an hour but what I did not like was in order to get to the speed I'd log with in 2nd range, I had to build up revs way too much for my liking. Other brands may be different but this is a light tractor that I need all the grunt it can produce because of the way I use a tractor and for me, that meant gear in this model. Taking possession next week. I made one last ditch effort to stay with JD but here I'm buying a $20K tractor for 10K and my JD 750. Jd was costing me another 10K for a tractor a step up from the 3016 (3320). I may have paid 5 more but not 10 more. I loved the JD dealership but I have it against JD for choosing their price points as high as they do. Of course remains the question as to why the Mahindra dealership was showing 7K for my trade and the Motherland was only willing to go to 2K. Another plus is that the Mahindra dealership is only 10 minutes from my place and has been selling Mahindras since 2006 and Yanmars before that since 1981. So I'm feeling pretty righteous about the whole thing with any regrets now melted away. Thanks to all for the shoulders.
   / Hard time with new tractor #147
Cool, Congratulations on your new tractor.!
James K0UA
   / Hard time with new tractor #148
Congrats. I hope you enjoy your new tractor.:D
   / Hard time with new tractor #149
We need pics you know or it didn't happen.
I know… I know. I have pics of the tractor at the dealership but I'm sure you mean pics at my house. Here is the tractor at the dealership.
Jisan Heavy Duty CAT345 72in Excavator Bucket (New/Unused) (A59225)
Jisan Heavy Duty...
2018 Ford F-150 4X4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A56857)
2015 Vermeer SC362...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
SKIL SAW 10" TABLE SAW (A58374)
SKIL SAW 10" TABLE...
LANDHONOR LHR0300 HD CONCRETE FLOOR SAW (A52708)
LANDHONOR LHR0300...
