Hard time with new tractor
   / Hard time with new tractor
Why couldn't you load ags? The size might vary some, so perhaps less weight, but I doubt you would notice that much difference.
You can certainly fill ags and i would not own this size tractor w/o filling tires no matter what they are.. A 43" industrial is taking on 45 gallons of Rim Guard. I do not know what an 11.2 ag can hold but my 9.5x24 hold around 20. Perhaps the larger ag can hold 5 or 6 more gallons. I think you would notice a difference especially if you are trying to lift something heavy. The loaded ind tires make the tractor weigh 500 lbs more than the loaded ags which in my mind is not so easily dismissed even if the ags provide more traction.
   / Hard time with new tractor #132
And traction is power.
   / Hard time with new tractor #133
Arrow,
Posting at the same time, but just to explain, 95% of the time I use Med at 1500-1800 RPM, for deep woods maneuvering or delicate work I use low, for transport and plowing snow Hi range to curl the snow off the drive.
The difference from 8 speeds manual to a 3 speed hydro you have infinite speeds and torque in each range, so think of it as a 15 speed but you control the speed and torque applied with the hydro.
Carl
True but traction is also dependent on foot print. I've only owned ags so I cannot speak to all situations. The ind. tires I tried this aft had more force into the pile. The ags broke loose and started digging. Pulling tractors have relatively shallow lugs but their foot print is much larger. I think the industrials had the better traction as a result of providing more foot print on a harder surface. Now on wet leaves with a couple inches of snow, who knows? Without knowing for a 3500-4000lb machine in such conditions, its probably safer to stay with ags if I did not want to spend the money chaining up the industrials..
   / Hard time with new tractor #135
Arrow,
Carl
Arrow,
Carl
Carl, I dunno if all hydros work the same but in order to get more speed out of the Mahindra, it was a matter of adjusting the column mounted lever. The pedal would only allow so much speed before you had to increase speed at the lever. I should ask if I can attach my truck to the hydro and attempt to pull it up the incline.
   / Hard time with new tractor #137
Arrow,
I am no expert in fact know little to nothing about Mahindra. BUT, my experience is tractors since the 60's (IH 86 Hydros) and today's hydro transmissions are not too different, just better.
The final drive ratio - Hi-Med-Lo is mechanical, the input is the hydro pump, thus the final gearing is mechanical enabling the hydro pump swash plate (controlled by the foot pedal) allows more/less fluid into the final drives.
I doubt that Mahindra is any different, should be a Hi-Med-Lo range, and then a pedal on the floor to control the swash plate of the hydro.
Others that have Mahindra 3016 hydro out there? I know PSUTundra in PA just bought one..
I like to understand how the Mahindra is set up as it sounds odd by your explanation Arrow..
Carl
   / Hard time with new tractor #138
Missed it by a day Carl. I spent this aft and drove both tractors. Did a bit of digging with them as well. Let's take price out of the equation. The truth of the matter is I seem to be ambivalent about the whole thing. There are things I like about the hydro and things I don't same as the gear. I feel i have more control of torque and speed with the gear but going back and forth is certainly easier with the hydro. I don't like the fact that the hydro had to scream to go up this incline he has there when in high. Perhaps one needs more hp with hydro such as the 3616 has? Dunno and I'm not done yet. If I have a 2000lb stem attached and going up an incline, I'm certainly not going to appreciate going too slow or a tractor needing to peak out its rpm range. The gear was easier to handle this time but I'll definitely give the hydro a couple more goes before I decide. With cars and trucks, I drove sticks all my life and still prefer them but I seem to be of the minority. Perhaps this may be why I'm not as taken with hydro as some here.
I did experience something surprising to me considering all that's been said about industrials and that was on dry, packed gravel, the industrials had more bite than the ags when walking into the gravel pile he has there to test out fels and such. The guy at the dealership said I'd notice a difference if I had to go through a mud hole he said the industrials would act like slicks. Couldn't tell you either way as I have only owned ags. I do like the fact of the added ballast to be put into the industrials. One of these tires filled would weigh over 500lbs and probably closer to 600 if you count the tire itself. That's quite the ballast.
If you were to go with the 3616, you get 29% more HP, and you can do a lot more with that power. My 3215 HST dynos out with 34HP. My tractor ballasts out at 5000lbs. I can push up against an immoveable object and spin front and rear tires in all 3 ranges. I can travel in high range up hill at 11MPH without problem. I have NEVER had a want for more HP with this tractor. Now that is with 6 more HP than what you are testing. The 3616 has 8 more HP than what you are testing.
You asked about travel speeds, my 3215 HST is the following. Low range, 4.5MPH max, Mid goes 8MPH and High is 11MPH. The 16 series should be the same or very close.
Something to consider, but then where do you stop? :confused3:
Good luck with your research. ;)
   / Hard time with new tractor #139
Hi on a hydro is only for cruising on a flat road, or similar tasks. You will get more use out of medium all day long. I seldom go to low, or high, on a daily basis. Sometimes lifting your foot off or easing off the forward pedal will allow the hydro to give you more power. It's counter-intuitive but it works well. Planting the pedal to the floor will not give you more power in a given range. It takes some learning curve, but it is easy to adapt to if you've never done it before. RPM setting can be done on the fly and will become known as to what to set it at for a required task. My tractor came with industrials, loaded, and I use Aquiline chains for plowing during the winter. Put it in medium and tow your truck up Everest.
   / Hard time with new tractor #140
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
1995 TALBERT 50 TON LOWBOY TRAILER (A58214)
1995 TALBERT 50...
20Ft. Bi-Parting Wrought Iron Gate (New/Unused) Galvanized + Powder Coated (A59225)
20Ft. Bi-Parting...
Heavy Duty Skid Steer Breaker (New/Unused)(Est. Retail Value $4,800). (A59225)
Heavy Duty Skid...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
