Hard starts
   / Hard starts #1
bundyal
Boaz,Al.
Ford/Old
I've got an old T7.When I try to start it I turn the key and it hesitates for a second or 2 before the starter kicks in.It will start every time tho. I put a new battery,cables starter solenoid and starter switch in it.Any ideas?
   / Hard starts #2
I'd suspect the ignition switch and dried inner lubricant.
Squirt some solvent/lubricant via the key slot and that might just cure it.
I've used WD40 that way with success.
   / Hard starts
Its a new switch. The original switch did the same thing.
   / Hard starts #4
Good wire connections? also power pos. neg. clean?
   / Hard starts #5
I had something similar going on and it turned out to be corrosion in the main pos cable. Couldn't see it from the outside. The multi meter showed a ridiculous amount of resistance. Cut it open and it was a green crusty mess. Replaced it. Good to go.
2014 JCB 930 6,000LB 4x4 Rough Terrain Straight Mast Forklift (A49346)
2014 JCB 930...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A50397)
Mitsubishi FG35...
2003 Chevrolet Silverado 2500 Pickup Truck (A48081)
2003 Chevrolet...
2012 Honda Civic LX Sedan (A50860)
2012 Honda Civic...
Kioti DK45 Tractor (A50860)
Kioti DK45 Tractor...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
