Hard starting Jinma 354
   / Hard starting Jinma 354 #1
gergstuff
Ferndale, WA
Jinma 354
I have a Jinma 354 2007? It has very few hours on it, 30? Now that cooler weather has arrived it has become very difficult to get it started. I had an a-ha moment reading some other threads yesterday not realizing that holding the key in the "H' postion would activate the glow plugs and in theory make starting easier. So last night I was out there and could hear a click when I held the key in the "H" postion. I held it there for at least 20 seconds, cranks fine but would not start. I did this perhaps 4-5 times before it finally started but that is no different than the way it would start before I realized "H" activated glow plugs. So, I am assuiming something is amiss with the glow plugs or the circuit. Any idea how to test to see where the fault is?
I should be able to move it inside as soon as my shop is completed but it would be nice to have it start easier and save the starter, etc.
Thanks for the anticipated help!
Craig
   / Hard starting Jinma 354 #2
Might check to make sure the FUSE for the glow circuit is OK and then make sure the WIRE to the GLOW PLUG BUS BAR is hooked up. Some of the 354's came WITHOUT glow plugs and other have complained there were glow plugs but no wires.
The H is the HEAT and 20 Seconds is TOO LONG 10 seconds max for these tractors.
Look at the Left Side of the HEAD close to where the FUEL Injectors are there should be some spark plug looking things those are the glow plugs. there should be a 3/8" wide copper bar between them all. the Wire should be from the fuse to the end of that bar, maybe connected UNDER the end glow plug. The CLICK is or should be a Relay turning on and powering the glow plugs.
Mark
   / Hard starting Jinma 354 #3
I have a 2007 354. When the glow plugs are working, when I put the key into the H position the ammeter is pinned, all the way past 30 Amps. As they warm up the resistance increases and the current drops. I usually hold the key until the ammeter gets to 20-25 and then try starting. Actually, what I usually do is use the compression release and crank until the oil pressure comes up, then stop cranking and apply glow plugs, then crank with compression release until the oil pressure comes up again, then release the compression release and keep cranking.
On mine the fuse is only 30A and blows all the time.
   / Hard starting Jinma 354 #4
These tractors come from the factory with no relay in the glow plug circuit, though they certainly need one. As already noted, half the time they're not even hooked up, or missing altogether. I'd start by getting a 12v 40 amp relay and installing it in the glow plug circuit so the key switch is only handling an amp or so for the relay coil. Then run a piece of 8 or 10 gauge wire from the battery positive to the relay contacts and another from the other contact on the relay to the glow plug bus bar. If you want to do it even better, run the heavy wire so it goes through the ammeter so you can tell if the plugs are heating by watching the current draw drop off.
   / Hard starting Jinma 354 #5
to the op. have you checked for power at the GP BUSS BAR WHEN HOLDING key in heat?
( sorry for caps. darn tablet.. )
   / Hard starting Jinma 354 #6
You say cooler weather.....
I installed an inline coolant heater in my rad hoses....the little tractor starts much better when it's been plugged in, and I am out in the snow in -35C sometimes.
   / Hard starting Jinma 354 #7
I have a buddy that has a 2008 Jinma 254 and that thing starts horrible in colder weather, he has put an inline heater in the lower radiator hose as well as a magnetic heater and also has covered up the engine with sheet metal and insulation to keep the heat in.. It starts great in cold weather as long as the engine is warm ha ha:laughing: I'm thinking these Jinma's are warm blooded.. Can't seem to find if you can get an actual block heater for them.. Keep that engine warm and it'll start every time..
   / Hard starting Jinma 354 #8
Glow plugs?
//greg//
   / Hard starting Jinma 354 #9
I say he has an issue with the glow plugs or his starting method, my 284 starts great... I've fired mine in -30 before with a few additional warmers on the machine but had done it with glow plugs only @-20F NOT that i wanted to work in those temps....
Mark
   / Hard starting Jinma 354 #10
Yea, he has a glow plug issue or just does not know how to use them. Mine has started fine for 11 winters now.
Chris
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
LandPride PFL1242 Pallet Forks (A50120)
LandPride PFL1242...
1998 Volvo Dump Truck (A50323)
1998 Volvo Dump...
John Deere 7130 (A50120)
John Deere 7130...
1000 gal Fuel Tank (A50514)
1000 gal Fuel Tank...
Woods 3 pt Box Blade (A50515)
Woods 3 pt Box...
