Hard start
   / Hard start #11
I know this is old, but I went through this with my Cub Cadet LT1045. I had to crank it for about a minute total, on and off before it would pop off and when it did, it ran great. But on cold start, it always took wayyyy too much cranking. I replaced the battery, fuel filter, fuel pump, and other things trying to figure it out. If I sprayed a bit of gas into the carb and then started it, it would pop right off.
The problem was the fuel cut off solenoid on the bottom of the carburetor bowl. It was toast and block flow to the carb when I turned the key on. I replaced it this morning and after two years of this problem, I have my old lawn tractor back.
The part was $10.50 on amazon.com for aftermarket.
   / Hard start
Was it hard to replace this part?
   / Hard start #13
very easy. Just disconnect red lead wire, then unscrew it from the carb with (I think) 1/2" open end wrench. Put the new one in, reconnect the wires and you are done. The original had just a red 12V+ wire that has an in line connection and the solenoid grounded through the body. The new ones have a 12v+ and 12V- wire. The red 12V+ goes to the same in line connection and the 12V- goes to a ground source. There was one right next to the carb that I used. That's it. Done. Once you get the shroud off so you can access the carb, it is as simple as replacing a spark plug really.
   / Hard start
Now I am having trouble finding the part! Lol
   / Hard start #16
sdcarter: Do you mean the new part or the old part still on the mower?
   / Hard start
The new replacement solenoid, it's a Kohler Courage SV720
   / Hard start #18
Chances are good that it would be the same solenoid as I used. I think that one is used on many of the Walbro Carbs.
Case Titan 3530 (A56438)
Case Titan 3530...
John Deere HD300 Sprayer Utility Cart Attachment (A56857)
John Deere HD300...
40' x 20' All Metal Carport (New/Unused) (A59225)
40' x 20' All...
RING 2 STARTS HERE @ 9:15 AM (A58375)
RING 2 STARTS HERE...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
WACKER NEUSON SM120 STAND ON SKID STEER (A52709)
WACKER NEUSON...
