hard sided glass cab
/ hard sided glass cab #1
majorwager
western new york
kubota mx 5100 IH 484 ford 1620 lull 844b
If factory enclosed cab were an option, would sales substantially increase? Especially on larger versions?
/ hard sided glass cab #2
I don't think they want to grow sales past where they are at now. I know several folks wish they had cabs. I thought about it for a while, but I used to own a cabbed tractor. A late 70's IH 2500b tractor loader. Working in the woods, the glass took a beating. And there was no air conditioning, so in summer I had to remove the doors and back window or bake to death. In winter, it was nice, though. Had a little round heater core with internal fan, that was mounted on the ceiling. Hardly needed it once the transmission warmed up. But for the work I do, I want it open station in the summer. Plowing in winter isn't bad at all. I have the proper clothing. I ice fish as often as I can, and I'm used to it, and I just don't get cold. Plus, its so fast at plowing with the power angle blade on the FEL arms, I'm rarely out more than about 20 minutes anyway, and 10 of that is warming up the machine. I shovel the walk and steps, and by the time I'm done, the machine is warm and ready to go.
I suppose if I was a commercial operator with a blower I might want a cab.
It would be fairly easy to make a hard sided cab out of foam core and hang it from the ROPS. You'd need some sort of fabric skirt on the lower/rear section to allow for the total tilt and oscillation. I've actually hit the rear corners of the arm rest on the engine cover in full articulation and oscillation, that's how much the machine flexes. A hard cab would get shattered or dented.
Guess it is just me, but that cab, especially with A/C appeals. Thanks for sharing Impulse.
/ hard sided glass cab #5
I remember that one. There's a couple more with cabs out there somewhere, too. I can't figure out how that thing could oscillate without smacking the back, bottom corners on the rear section. Maybe they limited the oscillation on that one. It's an old one, as there's no quick attach on the FEL arms. It's the 3 pin.
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2012 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2012 TROXELL 150...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
Light plant Generac Magnum (NONE TITLED) (A63569)
Light plant...
2023 CATERPILLAR 299D3 XE SKID STEER (A62129)
2023 CATERPILLAR...
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
