Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #10,411
I bought one a while back and have used is many times good tool for the money.
   / Harbor Freight Tools that don't suck #10,412
With me the problem is remembering WHERE I put the specialty tool when I need it X years later.
This one was easy. Went right in the toolbox drawer with the other screwdrivers. :thumbsup:
$2.99. I thought the ratchet was rather tight for such an inexpensive tool. No slippage at all.
   / Harbor Freight Tools that don't suck #10,413
I had purchased thw older version years ago but when I saw the knob on the top to speed tighten/unscrew it's a much better tool.
   / Harbor Freight Tools that don't suck #10,415
Do they really NOT have a right angle chuck?
Sometimes you have only an inch of headspace and that ratchet screwdriver is the only thing that will get in there. I wish I could remember what I needed it for, but I recall it avoided a half hour of disassembling something that was blocking access.
   / Harbor Freight Tools that don't suck #10,416
I know, I have that one.
But I need a right angle chuck for a drill. They have a low profile drill, but that's not what I want.
   / Harbor Freight Tools that don't suck #10,418
Has anyone here ever needed to replace the original brushes with the ones that were included with their electric tool. I think I did it one time and confirmed that bad brushes weren't the problem.
I'm pretty sure my $10 grinder needs new brushes, it sparks all over the place now. I have had to repair the cord multiple times and found a set of brushes that are now taped to the tool to try. I just haven't got there and I have 5 other grinders if needed.
Looking forward to Rockcrawler reviewing that new tool set. :)
   / Harbor Freight Tools that don't suck #10,419
I'm returning them
I found the Ridgid 5 tool deal for $279 and ordered that. For around $80 more I'll have the 1/2" impact, 1/4" impact, drill, 4.5" grinder and LED light plus a 2 amp battery and 4 amp battery and a single charger.
I can't pass that deal up.
   / Harbor Freight Tools that don't suck #10,420
I picked up one of those right-angle ratchet screwdrivers last weekend while there for other things. Had the opportunity to use it this weekend to tighten some ceiling fan blades, and it worked just fine.
I bought something similar to this 10 years ago at HF but with a greatly expanded assortment of bits. My use was a one time only thing, or so I thought, but it turns out I use it maybe 10 times a year for obscure things from tightening a knife handle with odd screws to adjusting the carb idle on a tight clearance truck. If you see the expanded version, it's a buy. Only cost maybe $6 or $8.
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
Bale Ring (A50515)
Bale Ring (A50515)
2018 Wacker Neuson WL 38 (A52748)
2018 Wacker Neuson...
John Deere MX5 3pt 60" Rotary Mower (A50774)
John Deere MX5 3pt...
2011 PETERBILT 337 (A52472)
2011 PETERBILT 337...
