   / Harbor Freight Tools that don't suck #10,401
I have an 18 volt Ryobi string trimmer that is about 4 years old. I have not had any problems with it. The run time with a 4ah LI battery is good. I have never run out of battery when trimming after lawn mowing which usually takes me 45 min to 1 hour.
   / Harbor Freight Tools that don't suck #10,402
My experience with the Ryobi 18v string trimmer - it would be fine for urban lawn grooming. My actual use is to cut foot-high straw that is too close to the deck columns to cut with the tractor and rotary mower. This works, but cutting material that coarse breaks the string continually. And refilling the spool is a PIA. Buy a couple of extra spools to swap in mid-job!
I would like a tool powerful enough to trim the blackberry runners that threaten to go up my orchard trees - this isn't it.
Mine was a great buy in near-new condition at Goodwill for $10. Next time I dropped stuff off there I found the leaf blower for $7. Again, this blower is sufficient for minor use but its not up to moving windrows of large wet leaves.
I see there are several models of Ryobi 18V string trimmers and leaf blowers. I'm talking about the models in this photo. Here's the review article where I found the photo.
   / Harbor Freight Tools that don't suck #10,403
I didn't realize that Ryobi made an 18v string trimmer. How do they stand up? Run time OK?
It's OK. More time on bigger batteries of course. I can do around the house with it on usually one small battery, but I try to carry a second with me. The one I got is convertible though, either battery or A/C if I want to drag an extension cord around behind me.
   / Harbor Freight Tools that don't suck #10,404
Anybody (else) have the 'go through' socket set? Kind of a combination of regular and deep well sockets all in one with a special extension. I use my combination SAE/Metric set quite a bit.
   / Harbor Freight Tools that don't suck #10,405
I've had one a couple of years now, no complaints and in certain circumstances it has been invaluable.
   / Harbor Freight Tools that don't suck #10,406
<snip>
Can you swap the head for one with 3 blades?
https://www.homedepot.com/p/Rino-Tuff-Push-N-Load-3-Blade-Universal-Trimmer-Head-16234/100671846
   / Harbor Freight Tools that don't suck #10,407
I think the convertible trimmer may be more powerful than what I have, the version shown the photo above.
I should research if the 3-blade head will fit mine. That would be an improvement for cutting tough material.
   / Harbor Freight Tools that don't suck #10,408
I picked up one of those right-angle ratchet screwdrivers last weekend while there for other things. Had the opportunity to use it this weekend to tighten some ceiling fan blades, and it worked just fine.
   / Harbor Freight Tools that don't suck #10,409
https://www.redditstatic.com/desktop2x/img/loading.gif
Yes! That tool is one example of buying a specialty tool at HF for a single project and if you never use it again, it paid for itself already. I don't remember what I bought mine for but it was the only tool that would fit into a tight spot. I don't recall that I've ever used it again. Still worthwhile.
   / Harbor Freight Tools that don't suck #10,410
With me the problem is remembering WHERE I put the specialty tool when I need it X years later.
Massey Ferguson 92” PTO-driven rear-mount snowblower
Massey Ferguson...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
