MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 58,098
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Hey Moss... wrong thread... meant for 'do suck' thread? :laughing:I also have this set of locking pliers....
The bigger two are sort of OK, but the little one actually bends if I squeeze it with my hands. Again, kinda junky.
My experience exactly. I returned one similar - I think I bought it alone however - because a two-handed squeeze on the handles rounded off the slip-joint teeth and it jumped to the next looser tooth. Useless. I went out to the flea market and for about the same price bought used real Channellocks. The real ones have undercut teeth/groves that can't slip. Also better, stiffer steel in a lighter tool.Everything works great, EXCEPT the slop joint pliers on the right. If you put any pressure on the handles, the sloppy joints slip. Complete junk.
I saw the Metal Cutting Circular Saw recommended in an old post in this thread but it seems HF no longer sells them. ???
They have a twin blade saw that is advertized as useful in cutting sheet metal and bar stock. This one: 5 in. 7.5 Amp Heavy Duty Double Cut SawI saw the Metal Cutting Circular Saw recommended in an old post in this thread but it seems HF no longer sells them. ???
I have this plier set... and use it almost daily at my job. Everything works great, EXCEPT the slop joint pliers on the right. If you put any pressure on the handles, the sloppy joints slip. Completel junk. Too bad, because the other 4 pliers/cutter in that set are great for the money.
