Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #7,191
I also have this set of locking pliers....
The bigger two are sort of OK, but the little one actually bends if I squeeze it with my hands. Again, kinda junky.
   / Harbor Freight Tools that don't suck #7,193
4 out of 5 of the pliers work great. And two out of three of the locking pliers work just OK. So on average, they are still above the "sucks" level for the price.
   / Harbor Freight Tools that don't suck #7,195
Everything works great, EXCEPT the slop joint pliers on the right. If you put any pressure on the handles, the sloppy joints slip. Complete junk.
My experience exactly. I returned one similar - I think I bought it alone however - because a two-handed squeeze on the handles rounded off the slip-joint teeth and it jumped to the next looser tooth. Useless. I went out to the flea market and for about the same price bought used real Channellocks. The real ones have undercut teeth/groves that can't slip. Also better, stiffer steel in a lighter tool.
   / Harbor Freight Tools that don't suck #7,196
I saw the Metal Cutting Circular Saw recommended in an old post in this thread but it seems HF no longer sells them. ???
267305d1338316010t-harbor-freight-tools-dont-suck-image_6682-jpg-jpeg
   / Harbor Freight Tools that don't suck #7,197
I never found the saw on the HF Web site, however I have seen it in the store, but haven't seen it recently. Have been using one for several years now. Works great! Usually cut 16 gauge sheet metal but have cut 3/8 in plate as well.
   / Harbor Freight Tools that don't suck #7,198
   / Harbor Freight Tools that don't suck #7,199
I have this plier set... and use it almost daily at my job. Everything works great, EXCEPT the slop joint pliers on the right. If you put any pressure on the handles, the sloppy joints slip. Completel junk. Too bad, because the other 4 pliers/cutter in that set are great for the money.
I have this set, too. I keep it in my small tool bag. The cutter has been my guitar/bass string cutters for years. I've never had any trouble with the slipjoint pliers, though. Mine is fairly tight.
   / Harbor Freight Tools that don't suck #7,200
I have a set of their larger size pliers and they are great. They're about 40% bigger than regular and not always in the store. The little nut that holds the pliers together used to loosen up and slip but I put a little light duty Loctite on the threads and no problem since. You can also use women's clear nail polish. Anyway, I have three pair and they are my go-to pliers. The lighter duty plier are OK but too small for my big hands.
The only locking pliers worth anything are red--or mine are red--and they look far more rugged than the lighter duty set. It's obvious. They cost more but really work. The light duty ones bend and twist.
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2016 Ford Escape SE 4WD SUV (A50324)
2016 Ford Escape...
Case IH Precision Disc 500T (A50120)
Case IH Precision...
CFG Industrial Q.A Hydraulic Breaker (A50121)
CFG Industrial Q.A...
2008 FREIGHTLINER B2 BUS CHASSIS (A52141)
2008 FREIGHTLINER...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
