Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #5,051
...But often aren't usable for the same task as the real tool that HF copied. Those bar clamps are a perfect example.
The belt/disc sander I wrote about up in post #4969 is another case of a bogus unusable pretend tool. One of the latest reviews said he had to push the belt to help it get started, another said too much vibration for his intended precision woodworking. Both comments illustrate 'pretend tool'. Mine had a shipping tag showing 29 lbs (and that's what it felt like) while the website and carton claimed 41 lbs, again showing you aren't receiving what you expected.
HF's reviews can't be relied on to recognize the unusable tools. After writing that post referenced above, I wrote reviews on HF's website. The first I repeated most of the points of that post, then when it didn't appear I wrote another review much more concise. Review title 'NO", best use 'return for credit', then described how the sanding disc didn't protrude out front of its guard plus dragged against the guard - just like HF's photo! - making it impossible to slide material across the face of the disc and certain to self-destruct. They didn't publish that review either. Caveat Emptor (buyer beware).
My rule of thumb with HF tools is to pretend I am a 98lb grandmother using the tool and only apply forces that a granny could muster.
   / Harbor Freight Tools that don't suck #5,052
Yeah. Like you described, I have only used those bar clamps to stabilize something while the glue dried. No problems encountered in that limited application.
I wouldn't try to use them to pull something into alignment. For that, its time to get out the Pony Clamps.
   / Harbor Freight Tools that don't suck #5,053
Ya know, it seems like some HF tools suck, but other are OK. Maybe we should have a thread dedicated to identifying the good ones. :laughing:
Ok, point taken. :thumbsup:
But I started my discussion of this belt/disc sander with high hopes, I inquired here about others' experiences before buying this. The replies were favorable so I relied on this 'don't suck' thread and went ahead and bought one.
But those favorable replies must have described the earier 41 lb version, not the 29 lb version with same product number that I received. It seemed reasonable to write my followup here in the same thread as my initial inquiry.
Overall, I agree, they sell enough sucky stuff to deserve a thread dedicated to that. :D
...........But those favorable replies must have described the earier 41 lb version, not the 29 lb version with same product number that I received.............
Good point, that's why it helps to list the model number, as HF seems to be constantly changing the products. Sometimes they are even selling two of the "same" products concurrently.
   / Harbor Freight Tools that don't suck #5,055
One item that must have been improved is the newer black 90A AC 'mig' flux core welder.
The prior blue version of this generated a lot of complaints and discussion - 'how do I make this thing work properly?' - in the HF forum over on Welding Web. There's almost no mention of these after the upgrade to the black model. Hopefully the new owners now are getting the performance they expected, instead of flocking to a welding forum to ask what they are doing wrong.
   / Harbor Freight Tools that don't suck #5,056
I have the old blue HF 90A AC flux core welder. I can make good welds with it, but I've gone through several rolls of wire on it and have a lot of practice. My father-in-law, who is a somewhat competent welder, can't lay down a decent bead with it, even after I set it up. I used to think the key was using good welding wire, but I can even use the cheap HF weld wire now.
I have a Hobart 180, and in flux core mode, does better welds, beautiful, in fact. My FIL can lay down a decent bead with that.
Since I got the Hobart, I haven't used the HF model.
   / Harbor Freight Tools that don't suck #5,057
   / Harbor Freight Tools that don't suck #5,058
I've got the blue flux core welder and can do fairly well with it. I have made one modification and that was to add a fan behind the transformer. Use it primarily for lite stuff on the ranch.
   / Harbor Freight Tools that don't suck #5,059
Don't buy this!!!
19-1/2 In x 14-1/2 In 200 lb. Capacity Polypropylene Dolly Presently $9.95 with coupon.
Took it home, looked at the reviews that said it broke easily, stepped onto it ... and split it in two pieces before I reached near my 180 lbs weight. It didn't have any greater resistance than crushing a cardboard shoebox.
Avoid.
   / Harbor Freight Tools that don't suck #5,060
Don't buy this!!!
Avoid.
Go to the review section for that item.... :laughing:
CONS
Can't handle heavy loads (4)
BEST USES
Moving heavy objects (4)
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
2021 SELLICK S80 STRAIGHT MAST FORKLIFT (A51242)
2021 SELLICK S80...
2011 Chevrolet Malibu Sedan (A50324)
2011 Chevrolet...
City of Lakeland (A51691)
City of Lakeland...
1988 CATERPILLAR 815B PADFOOT LANDFILL COMPACTOR (A51242)
1988 CATERPILLAR...
