Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #15,921
On your pipe wrench that the teeth are bad can you use
a file or grinder to redo them? They are two pieces so you
can take them apart to work on them
willy
   / Harbor Freight Tools that don't suck #15,922
My dumb idea worked as good as I'd hoped... I had these magnets sitting around that are basically small magnet fishing magnets and they're the same diameter as the collar, loosened the set screw and put the magnet on and you can pull the magnet/collar off or pull the pinion shaft out but you have to be deliberate... the ratcheting method is neat and I might do that later but this was easy...
This may not be the place to ask, but does anyone use one of these presses to punch holes in metal? I'm not talking about sheet metal, but specifically, to punch holes in steel bed frames that are otherwise impossible to drill. Maybe 1/4" holes maximum of 1/8" thick steel.
If so, what die set do you use and how well does it work.
   / Harbor Freight Tools that don't suck #15,923
Steel bed frames are typically very hard steel. Most likely a high carbon steel and full of junk. I'd be willing to bet it would take 40-50 tons or more to punch a 1/4" hole in one (if your punch die survived). The frame and die would most likely shatter like glass. Drilling can be done with carbide drill bits, but the frames are brittle and may crack or break at the hole if stressed. It can also crack if welded. The stuff isn't particularly well suited to repurposing. The scrap yard is the best place for old bed frames.
   / Harbor Freight Tools that don't suck #15,924
Couple weeks ago I picked up a Bauer Brushless angle grinder open box (hey, $31 wasn't bad...) and 5030 isn't kidding, the brushless version is a complete different animal from the brushed version, more rpm and power and just as smooth, the square battery mounting is kinda silly and the switch is going to take some getting used to but I like it...
I've picked up a whole bunch of their hitch pins since they've been on sale the last couple weeks, will probably grab more tomorrow while I'm in town, $1.91 is a deal...
   / Harbor Freight Tools that don't suck #15,925
I have noticed a considerable difference in the performance with the different sized batteries. On the smaller battery it was almost useless on the larger battery it was very nice.
   / Harbor Freight Tools that don't suck #15,926
I only have one of the small batteries, a bunch of the 3ah and a couple 5's, the brushed grinder can only use a couple bars worth of battery, the brushless with it's controller is probably more efficient if I had to guess (I do have some experience with RC airplanes and cars so I do understand it isn't just a marketing gimmick) but yes, the high amp tools appreciate the larger batteries tremendously! For the most part I just use the small battery on the portable work light (that is fantastic by the way)
   / Harbor Freight Tools that don't suck #15,927
Immediate access is more important to me than the risk of something being taken by the orchard laborers who congregate there for breaks and lunch. These immigrant farm laborers are great people. Nothing has ever disappeared.
p1710751rspikeharrowlifted-jpg.307656
Agree with the honesty of labor crews. A couple of years ago, my Milwaukee impact wrench went missing for almost a year.
I suspected one of my vineyard crew must have appropriated it, but never asked them about it.
The following summer, I was working in the orchard, and there it was, sitting on top of a post. Yep, I instantly remembered using it for fence repair right next to the tree.
As a side note, stuck a fresh battery in it and it worked good as ever, even after enduring a very wet winter
   / Harbor Freight Tools that don't suck #15,928
The Hercules 11 amp 4.5" corded angle grinder is 50% off, $35, today Wednesday 12/18 only. Using the email '12 days of deals' coupon.
I have one, I recommend it. It is a near twin to the 11 amp DeWalt.
   / Harbor Freight Tools that don't suck #15,930
yesterday was the highly rated Hercules Miter Saw Stand for half price. It was a great deal on a very good stand!
2008 Toyota Camry LE Sedan (A55853)
2008 Toyota Camry...
2020 KUBOTA KX033-4 EXCAVATOR (A52707)
2020 KUBOTA...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2019 KUBOTA SVL95-2S SKID STEER (A52707)
2019 KUBOTA...
2018 Chevrolet Colorado 4x4 Ext. Cab Pickup Truck (A53422)
2018 Chevrolet...
NEW HOLLAND W80C WHEEL LOADER (A52707)
NEW HOLLAND W80C...
