Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #11,621
I did talk to my Kubota dealer about the 3 point and he didn't think it would cause any damage or be an issue. In fact Kubota used to sell the 3 point as well.
My sig photo below, and photos 1,2,3 in this post, show the backhoe that was sold with either Kubota or Yanmar logo on it. This was around 1980 for their 20~30 hp models. These are well made, if you find one used in good condition, get it! The Deere-logo versions for 650,750 etc have a near-identical operator manual so were likely also made by ARPS. Deere's have conventional swing-down outriggers.
   / Harbor Freight Tools that don't suck #11,622
If you use a 3pt BH you need to be extremely careful, you can bust out the rear of your tractor. That is why they are not readily available. You really need a subframe when attaching a BH to a tractor. You might get an opinion from more than one dealer!
   / Harbor Freight Tools that don't suck #11,623
I've put the backhoe on the back burner for now.
Just bought a zero-turn and that's all I plan to spend this year.
   / Harbor Freight Tools that don't suck #11,624
Here's a prior thread discussing just that question. See my posts in it where I reference a previous thread where I asked that, then went and bought a 3-point hoe instead. Now after a decade using the 3-point backhoe I think it was the right choice for my applications - mostly taking out stumps in my orchard for re-planting, and I've done a few ditches with it. Also used it to rip out blackberry jungle on steep slopes between the orchard terraces.
Moving a tractor-mounted hoe then setting up to work in various places around the property is a nuisance, seems to me moving that around would be 3x the nuisance. Especially backing into position on uneven ground. But owners like them.
You mentioned health. The HF backhoe would be easier to get on, compared to climbing up on a tractor-mounted hoe every time it is moved.
Some ROPS configurations make it impossible to safely add a backhoe, there is risk of a crushed spine if something breaks and you lurch upward. And 3-point hoes are known to break transmission housings - not all tractors are suitable.
https://www.tractorbynet.com/forums/attachments/113502-harbor-freight-back-hoe-trencher.html
Thanks,
Jim.
   / Harbor Freight Tools that don't suck #11,626
I believe we paid $1400 ($1399). My wife bought it for me as an early Christmas present and I think she ordered it through Lowe's website. I had been looking at them here locally, as Running's usually keeps them in stock.
That's not bad for all that performance. Thanks!
   / Harbor Freight Tools that don't suck #11,628
I got one batch of free batteries that was a joke, some wouldn't light a flashlight more than a minute or so. More recently I've been using the free AAA's in a cordless computer mouse. Those last 3 weeks. No complaints.
I've never found another application for the free batteries. They are too weak plus I don't trust them to not leak if they were left a long time in emergency storm lanterns etc.
they aren't great, but I've never had one leak. Duracell are the leaking battery king. almost everyone of them will leak. everready not nearly so bad.
I use in remotes, usually last a couple of months to 4 depending on how much they are used. I've got a cordless that I use every day and I use a lot and usually get 6 weeks or so., clocks, usually 5 to 6 months. I have two headset muffs that are noise cancelling and they work well in them. a Duracell almost ruined my good headset.
free is good.....
   / Harbor Freight Tools that don't suck #11,629
free is good.....
Interesting.. I've never had a Duracell leak..
   / Harbor Freight Tools that don't suck #11,630
I've seen this numerous times. Usually in a pieces of equipment that has sat unused and the batteries have gone dead. (A bit of a bummer for equipment you are leaving batteries in so it will be ready to go in an emergency.)
2016 MACK CXU613 MID-ROFF SLEEPER (INOPERABLE (A58214)
2016 MACK CXU613...
Pallet of 10 Chains and 5 Binders (A57453)
Pallet of 10...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A57453)
(1) HD 27ft x 24ft...
2021 CATERPILLAR D3 CRAWLER DOZER (A52709)
2021 CATERPILLAR...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
pressure washer, and trailer (A56859)
pressure washer...
