Harbor Freight quick hitch
/ Harbor Freight quick hitch
You then will need to use CAT II to CAT III bushings.
Yeah. Could not get my Cat. 1 pins loose without getting out my 6 ft pipe on the wrench or going upstairs to get air and use of my 450 ft lb air wrench. These Cat. 2 pins aren't any longer, and the bushings are too skinny to fully cover the pins. See my other note. Exchanged the Cat. 2 pins for Cat. 1-2 bushings.
Ralph
Look at Post #29 for the solution to the top hook bolt interference
I got a quick hitch adapter that comes with a full Cat. 1 pin. Just drilled out the QH holes with a HF step drill bit and am using the full Cat. 1 pin on top.
Why the **** do they make a supposedly "cat. 1" QH that isn't? Seems other QHs follow same practice. Why?
Ralph
OVERLAND VACUUM TANK (A60736)
OVERLAND VACUUM...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2012 MACK PINNACLE WINCH TRUCK (A60736)
2012 MACK PINNACLE...
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
