Harbor Freight Log Splitter Review
   / Harbor Freight Log Splitter Review #21
I have had a HF 20ton for about 10 years, split lots of wood with it. I bought it with an industrial BS motor. I used to have wood chips dumped on my property and the tree services would oblige me supplying me with wood. The problem was that most of the wood was up to 3 foot blocks, cut to any lenght they could manage with their crew, and was usually the hard to split leftover junk. The splitter I bought was a horizontal/vertical design, and I use it almost exclusively in the vertical position, with me sitting on a milk carton, manhandling the blocks into position to split. The little 20 ton split just about everything I've ever tried with it. I still use it yearly to put away wood for the following winter, but now it splits mostly beech, sugar maple, and cherry from my property where I retired. I run it a little above fast idle, you don't need something moving superfast when you get older.
   / Harbor Freight Log Splitter Review #22
I have the 30 ton HF splitter as well, this is the 3rd year using it. I split 5-6 cord of wood a year. Other than having to tighten some fittings and clamps when new it has been great.
I'm not sure what all the negativity is on the Briggs engines is all about, never had a bad one. The splitter has an 8hp BS OHV engine, starts easy and runs great. 3 year old Craftsman rider has an 18HP Intek always starts good and runs well. One complaint on that one though, it does backfire once in a while when you kill the engine. Our 8-9 year old push mower with a 5hp BS, same thing. The previous mower, 10 years, had a 3hp BS that we could not kill. Never changed the oil for 6 years and it had water in it when I did change it. We had this at our duplex for the tenants to use. Everything else went to crap on the mower though and finally junked it.
   / Harbor Freight Log Splitter Review #23
Ditto on the B&S. I used to hate them, but lately I'm liking them a lot. They all start and run just great, and last just fine. They're a bit noisier, not as torquey, and don't last as long as the Robin and Honda engines. But,,, they're not as expensive either.
   / Harbor Freight Log Splitter Review #24
I love that reply from BTDT. Good one. I have the woodstove, chainsaw, and pick-up truck. Quite an expensive proposition if you just want to heat the house or garage. I recently got a tractor and am going to get rid of the old Chevy truck. The tractor seems to be a versatile little machine.
Anyhow, thanks for the reveiw on the log splitter. It's on my "would like to have" list, but not at the top.
   / Harbor Freight Log Splitter Review #25
Ok, for those of you who have a HF splitter, a question...
When you replace the hydraulic fluid & filter what filter do you use? I'm sure that I could run down to Walmart and pick up a Fram filter but I have no idea which one. Anything specific I should look for?
Time to do some more maintenance to my equip. :)
Keith
   / Harbor Freight Log Splitter Review #26
I just posted my question under another thread. I didn't see this one.
Does anyone know if the 30 ton Harbor Freight splitter really has only a 1.5" diameter rod on it's 5" cylinder? That is what the online pdf file says. That is an unusually small rod for a 5" cylinder.
   / Harbor Freight Log Splitter Review #27
Anyone?
Yes?
No?
Maybe?
   / Harbor Freight Log Splitter Review #28
Hi DanMan.
I haven't been paying attention to this thread for a while but had to check it to see if someone had posted anything since I last wrote.
I'm not sure if the 30 ton has the 1.5" ram but I'm guessing from the manual that it's similar to the 24 ton that I have. The ram diameter is actually 1-3/4".
Unfortunately I had a setback a few months ago. I was splitting wood and noticed that I had hydraulic fluid pooling under the reservoir. Just this afternoon I took the rail assembly and the engine off the frame and will be taking the remainder of the unit to a welder friend I know. Hopefully he can seal the reservoir so I can get back to work.
The unit does have plenty of power and I've never had a problem with the ram unit itself.
Keith
   / Harbor Freight Log Splitter Review #29
I agree. Almost everything I have (Riding Mower, 5kw Generator, etc...) has Briggs and Stratton engines and they have never failed. I even have a very old push mower that I converted to a tow behind for cutting some hard to reach areas with a 3.5hp B&S that I have tried to kill so I will have an excuse to buy one, but it just refuses to die.
   / Harbor Freight Log Splitter Review #30
Not sure if anyone is still reading this thread, but can someone tell me if Harbor Freight ever has sales on these log splitters. I'm looking at the 24 ton Robins version and was hoping to catch it on sale. I checked the closest store to see if they have it in-stock so I could use the 20% off coupon they always have, but they were out. Cant use that coupon online or phone orders. Thanks!
   / Harbor Freight Log Splitter Review #31
You can use the coupon for "special order to store". You just have to pay in advance. Every once in a while the mail order website has them on sale and occasionally the stores seem to have a hundred bucks or so off
   / Harbor Freight Log Splitter Review #32
The Harbor Freight 30 Ton Splitter with lift is currently on sale for $1299 and I have a 20% coupon. Anyone have one?
   / Harbor Freight Log Splitter Review #33
where do you guys get these discount coupons? I get a couple of their catalogs a week but have never received a discount coupon.
   / Harbor Freight Log Splitter Review #34
   / Harbor Freight Log Splitter Review #35
Thanks for the link Travelover. I signed up but they never send me anything!
   / Harbor Freight Log Splitter Review #36
It is a mystery how they determine who gets coupons. I get them at 3 email addresses, or rather used to. Sometimes they all 3 get one, sometimes just 1 and other times guys on the forum get them and I get none anywhere...:confused:
   / Harbor Freight Log Splitter Review #37
Does XXX ever go "on sale" at HF?
Just about everything HF sells rotates through a price reduction sale. I try to wait till what ever item I want is on special and usually don't have to wait too terribly long.
Pat
   / Harbor Freight Log Splitter Review #38
The really nice thing is the %off coupons are even good on sale items. I've gotten some great deals if a sale on something I want coincides with a %off coupon:)
   / Harbor Freight Log Splitter Review #40
Thanks for the input. Someone was asking about how to get 20% off. Just go to:
Sign Up For Harbor Freight Offers
They'll email you a 20% off coupon (good for 1 item at the store only).
Alan
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
LMC 6' SOIL CONDITIONER (A59823)
LMC 6' SOIL...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
UNKONW  SPOOL TRAILER (A58216)
UNKONW SPOOL...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
