Harbor Freight Flux Core welders 2
   / Harbor Freight Flux Core welders 2 #1
HomeBrew2
Banned
Dunlap, CA
Kubota BX23
I thought it best to withdraw from the other thread due to the 'Fraidy Cat Club / Safety Police and I seemed to be detracting from the original posters intent.
I had to bring up some archives of my older projects so here is my first with the el cheapo HF 90A wire welder:
I got a decently priced ABS canopy off eBay a year or so ago. It just had individual mounts that clamped to each side of the ROPS. Worked fine but chattered quite a bit and deflected badly when I ran into an oak tree limb or the garage door header. I added the 2 cross braces to tighten it up. The welds look poor, in my view, but I smacked them with a 3# hammer after each weld and have been using it (read: running the canopy into stuff for some time now) and it has worked out worlds better than before. I cleaned the weld area and painted ... everything looks better painted ... now everything is covered with dust though.
My next project was my pipe fence entrance. I have a nice OLD 225A tombstone AC buzz box but due to lack of interest of hauling it and my 5500W Generac generator out, I thought I'd try the HF hot glue gun run by my little Honda 2000W inverter generator. It was 105°+ so my attitude and ambition were low. I welded the cross braces to the posts as fast as I could get into position for each pipe joint. The gate posts are 3" sch 80 and the others are 2" sch 40. The braces are 1.5" sch 40. I ran a table fan behind the welder cuz I was in no frame of mind to have it cut out due to heat ... it never did. Again, the welds look poor but each was smacked with an 8# hammer after welding (prior to the next weld) and all survived. I don't run any bulls here so, that was good enough for me.
Next I had to run some poly drip line across my drive so I wanted to slip it thru a steel pipe. Unfortunately, my pipe stockpile came up short and I had to glue a 9' piece to a 5' piece. I clamped them onto a piece of angle iron to keep the pieces straight. Welds were good. Plenty of traffic over the pipe and is working well.
Forgot the pic for previous post ...
Next was to add a few beads to the underside of my brush forks that I found that I had forgotten when I made them last year. The forks are 16 ga 1"x2" tube, quite strong for the total weight and do everything I need.
Next was just an experiment with welding material thicker than was intended for the machine ... a 1/2" bolt to a 1/4" plate to a 2" pipe. After completion, I noticed I got one of the bolts cockeyed but the 8# hammer fixed that and the weld was unaffected as anticipated.
Lastly, until I find other stuff to use it for, was to replace the leg extensions on an old table saw that I resurected from a field many years ago. It was a rusty mess then and isn't getting any better. I cut the bolts that held the old legs on then cut pieces of an old bed frame for the new ones then added some 1/4"x3"x3" feet.
So, it's been a while since I had to stop real work with the tractor and cobble up something. I have a 2" receiver hitch on my offroad golf cart and have pulled a mini-pickup bed trailer with it but have a junky garden-type trailer that I needed a little pin-type hitch for. The pic shows the welds attaching a 2" x 2" x 1/16"wall tube to a 2" x 2" x 1/4" piece of angle. This was not really possible for me to do with my tombstone with 1/16" rod so, the little HF welder earaned it's keep once again. Yes, all the steel was dirty, rusted and I was under the influence but the danged welder did a "usable" job (I chuckedup the wire wheel in the drillpress just to see the welds better) :)
   / Harbor Freight Flux Core welders 2 #9
What size toombstone do you have? ( and why was it not possibly to be welded with a stick? I've made plenty of welds with material in that size range using 1/16 and 5/64 rod on a 70a welder. Seems like a steady hand and 3/32 6013 rod on a bigger tombstone set to low range should work too?)
Soundguy
I have the ol' standard Lincoln. If you have seen the pix (link below) of my brush forks, I did them (all 16ga 'new' tubing) with the tombstone w/ 3/32" 6013. It was a nightmare, erratic sticking and burning. I concluded that I really need to renew the electrode holder, clean all internal connections to be able to use the very low amperages. It sat for many years in unknown conditions before I got it 15 years ago. No fault of the machine just my lack of attention to it ... much easier to spend money than do maintenance
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
Unused Delta Crash...
2025 New/Unused LandHero 40 Gallon 2-Stage Air Compressor (A51573)
2025 New/Unused...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
KMC 3376 LOT NUMBER 265 (A53084)
KMC 3376 LOT...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
