Handy little tip
/ Handy little tip #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
Not tractor related (maybe) but this worked great. Was putting a hitch on my car yesterday and had drilled two 1/2 inch holes in the underbody frame rails that had to have a Grade 5 carriage bolt and backing sleeve (parts shown are NOT to scale, just for example) installed in the boxed area, from the opening at rear of body a FOOT away from holes.
Instructions that came with hitch said to "fishwire" the two bolt/sleeve assemblies into place.
What I did, used hot melt glue to make bolt/sleeve one solid part, then tied a length of dental floss to it, in case one came loose from my claw pickup tool. But they didn't, and using this method I got both assemblies seated in the boxed frame rails in less than 30 seconds per side.
Hopefully this idea may help someone else. Sorry for poor quality picture but it shows the concept.
/ Handy little tip #2
That is a clever idea..:thumbsup:
James K0UA
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63688)
PENDING SELLER...
HOMEMADE TIRE DRAG (A63291)
HOMEMADE TIRE DRAG...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A61573)
2015 Ford F-350...
1061 (A63291)
1061 (A63291)
